Posts: 106 |
i have driven my 3L for about 2K miles and i just realized that there is no moosing. when i had my 2.5 in there it would moose every time it was idling. why no moosing with 3L?
ADAM NYGAARD
97 GREEN GL MTX 3L HYBRID, 3L UPPER AND LOWER INTAKES, 24# INJECTORS, RES. REMOVED, INDIGLO GAUGE FACES.
98 BLACK TAURUS SE 3.0 DURATEC
Posts: 6,106 |
It's obvious!! The extra horses that you added killed the moose
2000 Black CSVT
Posts: 1,165 |
'01 GTP: 3.3" pulley, Headers, 3" Exhaust, Straight Pipe, Intense Air to Water Intercooler. Pictures
Old Ride: 95 Mystique LS V6 ATX: Pictures
Redneck Troll
Redneck Troll
Posts: 2,621 |
The added air the 3L is pulling in at idle makes the IAC run open in a slightly different position than the 2.5 did. Mine didn't moose for about 6 months with the 2.5 intake on it, then the moose came back. He must have grown up a little bit because his voice changed an octave!  Just give it time... I'm sure he'll be back to visit you too. Originally posted by Tim: What's moosing ?
Moosing is an air resonance that occurs on our cars through the idle inlet tract. Usually it first happens a couple of times on cold starts, then becomes more frequent as the IAC motor becomes dirtier over time. The throttle hang fix usually takes care of it, as does cleaning or replacing the IAC. IAC = Idle Air Control if you didn't know.
http://www.bnmotorsports.com
Posts: 1,165 |
hrm.. I've never noticed any kind of an air resonance when I started my car on a cold day. Interesting. Maybe I'm just not understanding what you're calling an "air resonance." What does it sound like, if you had to compare it to another well-known sound bite ? And don't say a moose
Posts: 7,025 |
well...if its not a moose then id say a foghorn. believe me, its unmistakable!
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 5,810 |
The 3L pulls a tad more air at idle and that does change the idle position as PA stated. However, I never had moosing period UNTIL my IAC valve was replaced with a stock duratech V6 valve. They have different part numbers, so I traced it back to the dealer where they installed the wrong one. They ordered the correct valve and from then on it was like normal. Still is.
If its an SVT it probably won't come back. IF its an SE, don't worry unless it does come back, then change IAC to the SVT version of it.
See My Mods
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by warmonger: The 3L pulls a tad more air at idle and that does change the idle position as bnoon stated.
Ahem!!!
Posts: 5,810 |
Originally posted by bnoon: Originally posted by warmonger: The 3L pulls a tad more air at idle and that does change the idle position as bnoon stated.
Ahem!!!
Whoops!
Well in my defence, PA is the moderator. He SHOULD have posted that first!
lol
See My Mods
Posts: 1,541 |
Originally posted by warmonger: Originally posted by bnoon: Originally posted by warmonger: The 3L pulls a tad more air at idle and that does change the idle position as bnoon stated.
Ahem!!!
Whoops!
lol
"I AM THE GREAT AND POWERFUL OZ. (Pay no attention to the man behind the curtain.)"
FWIW, my IAC never ever moosed until a month after the 3L came to life. Imagine my surprise when a CEGer told me what that horrendous noise actually was.
