Page 2 of 3 1 2 3
#65567 07/09/02 09:07 PM
This small diffenence in tires wouldn't give a difference in gas milage of over 10MPG. Something else is wrong.
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
#65568 07/09/02 09:28 PM
Originally posted by jeffyscott:
205/60 means 205 mm wide and height of sidewall is 60% of width or 123 mm. 123 mm is 4.84 inches so since the overall diameter involves two sidewalls it is about 9.68 inches plus the rim diameter of 16 so 25.68 inches in dameter over-all.
Stock is 185/70-14 which comes to 24.2 inches overall diameter. So you are only about 6% different from stock. When your odometer says you went 100 mi, you actually have gone about 106.
Nice, thanks for that information.
Today I looked at the driver side door and I saw a bunch of tires I can use. 205/60 is one of them.
Yes this 6 mile difference should not alter the MPG by 10 or so... I don't sense anything wrong while driving the car.
96 Contour GL
#65569 07/09/02 09:38 PM
Change your plugs, plug wires, air filter, fuel filter (might as well hit it), check your tires for proper inflation and then see how things react. Always start with the cheap stuff if you haven't done any maintenance of the sort in a while and if you don't have a specific idea of what your problem is.
I can tell you right now that it ISN'T your rims, unless they weigh in about 50lbs. a piece and you're running 6-ply trailer tires on them...
The lack of a CEL has got me questioning whether it could be your O2 sensors, but have your local shop check them just in case (stranger things have happened on Contours). Also have them check your ignition timing as well.
It could also be that your cat is getting clogged up, too. There are just too many variables for one swipe, so you're going to have to start eliminating some of the cheap and easy ones first.
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
#65570 07/09/02 10:57 PM
Have you done any performance modifications? If so did you reset the computer?? If not then why?
http://www.pbase.com/contourconcepts/contourconcepts
Motegi rims and lugs, Custom decals, soon I will have custom air brushing and corvette hood scoop, custom interior pieces and fiber glass enclosure in the making. kicker 900 watt amp w/2 kicker comp vr subs, pioneer xm radio, functioning euro antenna, clear interior brake light,CAI, blue bulbs and apr spoiler. Nitrous kit sitting in garage waiting to be installed, along with msd dis ignition wich is to be put on by MSD tech's who insist it will work. waiting on manual tranny and svt conversion parts. 2.5 v6
(DJ Says) "Hey our Contour may not be the quickest car on the streets but its been proven to whip a few of those Celicas here and there."
(Lil Timmy Bojangles Exclaims) "EVEN THE ONES WITH THE CHROME EXAUST TIP AND THE 6 FOOT WHALE TAIL??"""
(DJ Responds) Yes Lil Timmy ..Even Those Ones. =oÞ
#65571 07/09/02 10:59 PM
Hmm, thanks again.
I changed the spark plugs and timing belt when I got the car.
Maybe I'll check the cat and I know nothing about the O2 whatever. mad
96 Contour GL
#65572 07/10/02 12:46 AM
Changed the timing belt? Did you take any notes what kind of mileage you were getting before you changed the tires and before you changed the timing belt?
Not to say the timing belt change was done incorrectly, but it would be a good idea to at least double check correct installation. This would eliminate or identify a possible problem.
#65573 07/10/02 12:13 PM
I
I
This past winter, I experienced the same thing while at school. For about a month, I averaged about 14 mpg (not to pleasing). As noted above - definately change out the plugs and filters. It's the first thing I did, and it brought my average back to the high 20's (for combined city/highway travel.)
Travis Corley
'96 Zetec
CTA Motorsports Aluminum Intake
#65574 07/10/02 02:48 PM
Also it may be the thermostat is stuck open and the engine takes a long time to come up to temperature if it does at all. The PCM has a programed temperature where when below this preset temperature, it runs the engine at what I'm going to call, warm up mode where teh PCM commands running a richer mixture among other things, and when above this temperature it runs in what I'm going to call normal mode.
depending on how easy or difficult it is to access the thermostat, it is sometimes just faster to change the thermostat than try to trouble shoot it.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#65575 07/10/02 03:39 PM
Argh, I did not put any mods into it. The spark plugs were changed along with the wires. I did not record the MPG before the timing belt change because I did it once I got the car.
BTW which air filter are you talking about? I opened the one on top of the engine and it seem very clean.
This is fustrating. confused
96 Contour GL
#65576 07/10/02 05:38 PM
If your CEL light doesn't come on for just a second when you first start the car, the light is probably burned out. Replace the bulb and confirm that you really don't have any CELs or faulure codes. If you have 16" rims, and 205-60 tires you will probably here rubbing when you go over bumps. 16" rims usually require 50 series tires IIRC. (You probably have 205-60 R15) H is the speed rating.
Scott
Page 2 of 3 1 2 3
