Posts: 271 |
my right bicep is a (seemingly) bigger than my left one. it's really pissing me off, because i can't seem to even them out. when i noticed it, i tried to lift a little more with my left arm each time, but they don't seem to be evening out fast enough. i am right handed/armed, so i understand that my right bicep will probably always remain a LITTLE bigger, but this is ridiculous.
latest mod: SVT speakers
Posts: 1,812 |
1) Stop masturbating with your right arm. Switch things around once in awhile. 2) Instead of using seperate dumbells, use one of those curved bars used bicep curls and do them at the same time. Also, make sure you are using proper form. If you keep using seperate dumbells for seated bicep curls, than make sure your form is consistent for each side of the body.
1999 Black SVT
"If I were an admin I'd ban you without a second thought. " ~Trapps
Posts: 260 |
Stop doing straight/EZ-bar exercises and use dumbbells only. ISO curls will work great at fixing that. To think since you are right handed - the right half of your body will get better results is not accurate.
2k silver svt #1721
Ignorance breeds stupidity..
Posts: 759 |
Yeah, its funny. I am right handed, but my left arm seems stronger when lifting with dumbells.
Posts: 1,421 |
Originally posted by mamisano: Yeah, its funny. I am right handed, but my left arm seems stronger when lifting with dumbells.
Same thing here man.
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res.
96 SE MTX- "The War Wagon"
"I'm in love with my car..."
-Queen
Posts: 1,812 |
My arms seem to be well balanced. I have been lifting for like 4 years now so maybe they just even out eventually?
1999 Black SVT
Posts: 7,025 |
get on steroids. your arms will get so big nobody will even be able to tell the difference
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,960 |
20oz curls occasionally but thats about it .....
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 271 |
Originally posted by fatmike: 1) Stop masturbating with your right arm. Switch things around once in awhile.
good one. i knew somebody would say that.
Posts: 271 |
Originally posted by unknown: Stop doing straight/EZ-bar exercises and use dumbbells only. ISO curls will work great at fixing that. To think since you are right handed - the right half of your body will get better results is not accurate.
iso curls? what are those? i don't want to stop benching, because i still want my pecs to get bigger...or do you mean for the time being?
