#65489 07/07/02 08:43 PM
E
eagle98 Offline OP
E
I have a 98 w/ 2.0L Zetec. I'm almost certain my head gasket is leaking in the center, causing the two center plugs to get "cruddy", causing lots of pinging. I would like to put colder plugs in the two bad cylinders, to help eliminate the pre-ignition, until I can get this fixed.
My problem is I can't seem to get anyone to tell me what would be the part numbers for double plat plugs, that are two ranges colder.
Any info would be appreciated!
#65490 07/07/02 08:53 PM
9
9
Wouldn't you want hotter plugs to try and burn the crud off? At any rate, I think you should park the car until you get it fixed. Too much pre-ignition and you might hole a piston plus if the coolant gets into your oil, kiss your bearings goodbye. Sorry I can't tell you the numbers you seek but perhaps the Motorcraft website or some other website would be of help.
Karl
*** It's all about consistency! ***
98 SVT Contour
86 Ranger GT
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
#65491 07/07/02 10:02 PM
E
eagle98 Offline OP
E
Can't park it, need to get to work. Colder plugs would not cause the crud to get hot enough to pre-ignite/ping.
