#654667 06/05/03 12:22 AM
W
W
I do not know if you have read this post..
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=general&Number=306816&page=0&view=collapsed&sb=5&o=2&fpart=1
But it turns out a chunk of steel pinched and cut my SS break line.
I tried to call Todd at TCE and looks like he is out racing? (if you are good luck!!)
Does anyone have the specs on the wilwoods so I know what kind of line to get?
Also what vender?
or can I use the stocks (old OEMs) short term?
And DOT legal.
Thanks
Woz 2000 Contour SVT #136 Black with Blue leather 30% tint all around 12.2" Wilwood Billet NDL PS: I hate ALL Ford Dealers
6
Try www.precisionbrakescompany.com
I bought my Wilwoods from them with SS lines and they mate up just fine. I'm not sure if they still have them, but I have a good feeling they do as they still list the Contour on their site.
Mike
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535 Dear Santa
W
W
How long are your lines?
W
W
Ordereded.. Thanks.
Sorry Todd, your still my prefered vender! Because you support is AWSOME. I was just in a pinch and have a car rental I have to get rid off.
Sorry I missed your call. You should have left a message or emailed me. Still as the shop is closed it would have been next Monday before I shipped it.
The DOT thing is moot, the hoses are exactly the same regardless of what someone tells you. And yes, some of mine are, others are not. The difference is that the Contour uses an adapter to fit the hardline to the hose as well as the adapter on the caliper. DOT does not accept this, the hose end must screw directly into the hardlne and the caliper end must do the same or use only a banjo bolt. Regardless, the hose is no different.
Sorry to hear of your problem, I bet you are only about the fifth or so in over ten years to have such misfortune. If what you get does not work of course you can count on my getting you out one asap.
BTW, I was supposed to be testing on Pikes Peak this morning and tomorrow but we are 'snowed out'!!
Less Bling, more Zing Todd/TCE www.tceperformanceproducts.com
6
My lines measured right at 18 inches end to end.
Mike
Moderated by  Andy W._dup1
