Page 2 of 2 1 2
#65269 07/10/02 09:07 PM
9
9
Any special metric tools needed to change the pump?? laugh
96 SE V-6 MTX
SVT E1 rims,205/55/16 Comp TA VR 4's,custom exhaust,KKM filter,bullit fuel door
painted calipers,trans cocktail mix,tinted windows/body coloured grill/engine cover/SVT door sills
#65270 07/10/02 09:12 PM
V
V
No, I have a complete set of Metric tools (look at the bottom of this message and see what else I drive--you'll understand why) and I think it was a 10mm or a 12mm. Don't quote me on that though. Two or three of the bolts are longer than the others. Make sure you remember where they go when you pull them out--don't strip the threads!!
Also make sure you clean and dry the gasket mating surfaces before re-installing. I would either use some brake cleaner and a dry, lint free cloth. That would be the safest. Also check the torque specs and torque the bolts correctly. Don't over-torque are you will spring a leak.
Good luck and enjoy the honeymoon
Timothy Grimes
98 SVT
82 320i
http://photos.yahoo.com/svt98power
#65271 07/10/02 10:04 PM
I just drove to WI and back from CO and before the trip I changed the pump to the NAPA brand metal impellar one. Also replaced the thermostat ($8) as well. I did it because I did not want to get stranded out in Nebraska or Iowa in the middle of the night.
It's an easy job to do- it only took about 1 hour with just a few metric hand tools.
#65272 07/12/02 11:25 PM
9
9
Well,i finally broke down and changed the pump today,wasn't too bad,hopefully this means no problems in 2 weeks!! :p
96 SE V-6 MTX
#65273 07/13/02 02:30 AM
H
H
Originally posted by 96 contour seguy:
Well,i ......changed the pump today,wasn't too bad...
Do you mean the impeller's condition, the replacement operation, or both?
Hopefully you'll now both be pumping at 100% efficiency on the big H. smile
stock CD on LS, cass on LX
4 wheel discs on LX only
#65274 07/13/02 03:28 PM
9
9
Actually the impeller looked ok,but I figured better safe then sorry to change it-especially after talking to the ford dealers foreman who said that the waterpump was the biggest downfall on the 2.5 !!! laugh
96 SE V-6 MTX
#65275 07/13/02 05:30 PM
V
V
Good to hear that you were able to take care of the waterpump.
Just think how relaxed you'll be during your honeymoon laugh
Timothy Grimes
98 SVT
82 320i
Page 2 of 2 1 2
