Page 1 of 3 1 2 3
#648906 05/29/03 08:56 PM
blury Offline OP
What is the best paint for interior> Out crappy auto parts stores dont have that interior paint stuff. (or at least i havent found yet) i want to go black inside.
95 Tour ATX Zetec EGR Block OFF Polished TB Polishe Vavle cover Energy suspension Greaseable sway bar bushings Front and rear Red interior lights 1/2 done Home made short ram intake Custom Grills Watch this space grow
CEG road warrior
CEG road warrior
I used Duplicolor truck & van paint. Topped it off with Duplicolor clear laquer. No probs with chipping...as long as you don't paint your handles!
Yeah, don't do the inside door handles. I used spray paint from the Automotive section in Walmart
www.ChicagoCEG.com 2006 White Grand Prix
N
N
Just curious, why do you guys say don't paint the interior door handles?
Shawn Clone Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose Silver frost/Black Exterior-Midnight Blue Interior The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot I have 3 loves, my God, Brittany, and my Car.
they are referring to the actual part that you push and pull on with your hand with...the softer plastic handle(not the little black plastic one that has the plastic trim around it w/the lock buttons on it)...the paint wears off of it from your hands....
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
Not really on your hands but it does chip pretty easily
CEG road warrior
CEG road warrior
Too easy!
Did you sand the plastic first? or just clean and paint?
98.5 CSVT
CEG road warrior
CEG road warrior
Just clean and paint....sanding can be a PITA!!!
And you wonder why it chips.
on the "rubbery cheap plastic" handles in the cougar, if you sand well with 200 and then again with 400 and wipe clean with a wet towel, and then dry it, give it about 3 coats of duplicolor filler primer, sanding with 1000 between each coat and cleaning, then use about 4 or 5 thin layers of duplicolor paint (again, sanding in between each and cleaning up the dust), and then about 4 coats of clear (don't have to sand the clear if you did a good enough job earlier one)..
I have the handles completely black and we haven't had a problem yet.
2000 Dark Tourmaline Green Cougar - V6/MTX SVT UIM/LIM, SVT TB, 80MM Filter, Custom Burned MAF, 19lb Injectors, MSDS Headers & YPipe, YoDude DynoMax Exhaust, B&M Shifter, Enkei RS5 18x7.5, Roush Springs, Z3 fenders, custom interior, lots more
Page 1 of 3 1 2 3
