Page 3 of 4 1 2 3 4
#648853 06/13/03 01:51 AM
2
2
I have replaced my IAC once. The IAC that I cleaned successfully was the replacement IAC and not the stock one. At least for the 2000 V-6s there was only one part number from the dealer where I bought mine from. I even asked him if the SVT was any different and he replied no. The 95's might be different but I am pretty sure there is only one part number for the 2000 2.5 IAC, SVT or non-SVT. The other years I am not sure about.
#648854 06/13/03 02:18 AM
W
W
Can anyone post a picture of where the IAC is located or atleast give a good description of where it's located in relation to something easier to find. I am going to make an attempt to clean mine, but I'm not 100% sure where it is located. Thanks for any help.
Black 99 CSVT #1820 of 2760 -Current Mods- DMD, KKM, Koni-Kit, HPP rear strut tower bar, metal water pump, tinted windows, Pioneer DEHP4600MP, 6x8 Pioneer 4ways
#648855 06/13/03 02:26 AM
Go here for a description and a photo of the IAC. Click on the photo to enlarge it.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=7
2000 T-Red SVT, #562/2150
#648856 06/13/03 02:36 AM
The part number of the replacement IAC I got is XS2Z-9F715-BB. Can someone tell me if this is the correct part for a 2000 SVT? Although it fit, I'm now concerned about if it is the right part based on some responses in this thread. I would like to be certain.
#648857 06/13/03 01:35 PM
Form Fordpartsonline.com:
Fuel system - Fuel induction - Fuel injection - Idle speed control
IDLE SPEED CONTROL, F150-250, 5.4L, w/Supercharger 1999
IDLE SPEED CONTROL, Contour, Mystique, 2.5L, From 5/3/99 1999 - 2000
1999 Red / Tan SVT #1969 of 2760 Built 4/21/99 K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links 17" FSVT 5-Spokes Factory Spoiler 35% Tint All Around
#648858 06/13/03 02:17 PM
O
O
does anyone else have trouble searching for part numbers at fordpartsonline.com?
i can find the newer IAC, which i need (XS2Z9F715BB), but i can't find the gasket nor the tube assembly which is listed in the TSB, and the FAQ
BTW, the FAQ lists the IAC as XS2Z9F715BA which can not be found by any of the online parts dBs i've tried. the other parts it lists (the tube assembly and the gasket) are:
F8RZ9H308AA - Air Valve Tube Ass'y
E83Z9F670A - Gasket
but i can't find them. any ideas?
thanks
-eric
for sale: E0 (98) Silver Frost SVT/Contour http://contour.org/carprofile/carprofile.cgi?a=display&uid=667 wanted: front SVT bumper mesh, 01/02 S4 avant, nogaro blue.
#648859 06/13/03 05:04 PM
I
I
this number matches the original one I just removed from my '99 CSVT, so I would think it's correct.
contours, deloreans & fiats, oh my!
#648860 06/13/03 06:42 PM
I went to felpro gaskets for the IAC gasket, IIRC. I think the part number may be in the 3L forum (in the "stickied" parts list post).
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#648861 06/14/03 02:07 AM
W
W
Thanks for the link musicnut.
#648862 06/16/03 04:22 AM
I have been having a problem where it idles very rough. The whole car shakes at times. At other times it was fine. Now today I started it and it stalled right after it turned over. Then it ran fine and when I took it out for a drive, at certin lights it would idle at 2k............then down to 1.3k for a bit. Even after I bliped the trottle it didnt help. Now, it is fine. I have changed plugs,wires,LIM and UIM gaskets,PCV valve and cleaned everything. Is the IAC the problem you think? I have cleaned it in the past a few times before. I have 79k on the clock.
Dyno'd 182hp @ Spring Zing 18" Wheels H&R In-dash and stuff... 98.5 Red SVT
Page 3 of 4 1 2 3 4
