Should be fine. Specs are good for a subwoofer amp. Would suggest you check into HomeTheaterTalk.com or HomeTheaterForum.com for more DIY info on thier forums.
Also check Adire Audio at
www.adireaudio.com for their Tempest 15" driver. Makes a super sub for home music and home theater appls. Their Shiva 12" is very good, too, just the Tempest makes a great most-bang-for-the-buck setup if you don't mind the size (5-8 cu ft. ported sub pushing down to 16 Hz and lower)
Adire has a AVA250 plate amp, very much like the Stryke's, just rated at 250 watts instead of 350. Note that the 100 watts is really only a 1.5 dB difference. Adire's version comes with a gentle highpass filter at ~18 hz that stops ultra-low bass heavy DVD soundtracks from bottoming out your driver.
