Posts: 1,451 |
This is why I mentioned only spending 300.00 on the equiptment and save the other 50.00 for the installation. Once you have the amp and sub you can have them installed at any shop you want. There are plenty of good subs out there between 75.00 to 100.00 and then spend about 50.00 on a box and your good to go. This way your spending the same amount you were going to allready and chances are you'll have a better setup.
Vinny 2000 T-RED CSVT
MODS: 18" REV model 2 ST200 struts/Roush springs
CTA intake Pipe/K&N Filter
Dtec Heatshield
Optimized TB
True Duals w/ magnaflow mufflers/resonators
Posts: 133 |
Originally posted by SvtinAtl: 2Deep2,
A local shop is offering the Crossfire VR-142 (2chnl, 140w-rms) amp, with the Crossfire CF310 (10") sub mounted in a band pass box, installed for $349.00
I have never heard of the Crossfire brand, so I am curious to know if their any good. Secondy, how tight/clean will a band pass box be, I do not want a "farty/buzzing" sound. Lastly, how does the price sound?
Thanx, SVTinATL
Crossfire stuff is OK, but I think you could do better.
I think I would be very disapointed with the set-up even for my beater car.
The amp looks good but not for the sub.
I have heard the amps before and they are just as good as most amps. BiPolar op amps, Class A/B are all good stuff.
From what I have heard of the subs they are power hungry and simply lack. With low power you want Low moving mass and High motor force, which I don't think you have with the sub.
Since you are considering just a 2 channel amp, get more power and you don't have to look for low moving mass subs.
I avoid band pass because they can sound boomy. Band pass and Ported boxes tend to peak across a small range of frequencies. With proper tuning you can get a band or port to play low frequencies and over a wide band. MOST STORE BOXES will sound Boomy By DESIGN.
Still an EXTERNAL amp on all speakers will sound better than the amp in your head unit and one power grabbing external amp on sub.
I still want to shot the guy who sold me a 80 watt Alpine for the sub and 25 watt head unit for door speaker set up.
After fighting with the Store for my money back I went down the street and spent a few more dollars on 3 Orion Cobalt amps for all speakers for a 100% better system.
Anthony B. Davis
2Deep2 Silver SVT
2002 IASCA SQ Ult Ama 601+ World Champion runner up
2002 SLAP dBQ Champion
2000 USAC SQ World Champion
2002 USACi SQ World Champion
