In my (zetec) experience, the surging idle seems to be something that can be caused by anything that throws the air/fuel ratio off. Some things to check are: - clean the MAF element (and IAT while you're at it) - look for vacuum leaks - check air filter - check fuel filter - try injector cleaner
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
