Sounds like you are hitting a resonant frequency in that speed range. As stated, it is most likely a balance issue. Your tires are probably the culprit. This can be caused by losing a balancing weight or a broken belt. The rotors are probably less likely since you should feel some indication while breaking, but not impossible.
