Page 2 of 2 1 2
#64646 06/30/02 11:18 PM
E
E
TTT, I'd still like to know what I'm missing here.
...Ed
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#64647 07/01/02 06:50 PM
E
E
TTT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#64648 07/01/02 07:54 PM
It all just depends on how small the particals were. Filters in-tank are really just screens that block bigger chunks that can damage pump, but in-line fuel filter is paper element to block much finer particals. Sometimes running crappy Am/Pm type gas from chessier gas stations can clog filters quicker than if you run nice clean Chevron w/ Techron (for example)
'95 CONTOUR SE
-Enkei 16s
-Porsche944 Exhaust tip
- Audi xenon projector headlights
-Peterbilt 30" air horns
-mp3 Aiwa headunit (150 songs on one disc)
-dual 10s
-soon to have LED tailights (real kind, not just gay bulbs)
-That's it for now
#64649 07/01/02 08:04 PM
E
E
Sorry, not a good enough explanation...I have seen all three filters inside the tank. The filter disc is extremely fine, the sock is fine, and the pump discharge "injector style" filter is of xx micron (don't know the filtration specifics, but it is VERY EXTREMELY FINE laugh ).
If there is enough dirt in the external filter, with it's comparatively huge surface area, to cause problems, what pray tell, do the internal filters look like???
...Ed confused
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#64650 07/02/02 06:56 AM
Sorry, not a good enough explanation...I have seen all three filters inside the tank. The filter disc is extremely fine, the sock is fine, and the pump discharge "injector style" filter is of xx micron (don't know the filtration specifics, but it is VERY EXTREMELY FINE ).
Very fine yes, but nevertheless it is still just a screen. A very fine screen. But the paper external filter gets the really fine stuff. One thing we mechanics many times do, when we are curious (as you are), is we cut open filters to see what it was that had clogged them. Don't change your filter next time until it starts running like it's clogging up, and then cut it open and look inside. You see all the really fine mush (almost looks like really fine, fine wet beach sand or else that metal/ clutch wear slime that you find built up on the internal magnet on the inside of an auto tranny pan). Just make sure that if you cut it open, your cutting method wont cause any sparks. I always just use some tin snips or something, but don't use a hacksaw, as the friction can generate sparks and that would not be good for your eyebrows smile
'95 CONTOUR SE
-Enkei 16s
-dual 10s
-That's it for now
Page 2 of 2 1 2
