#640905 05/20/03 10:08 PM
I haven't had the funds for a D-TEC heatshield, so I decided to go to Home Depot and make my own.
I found a plastic plant pot that worked great. Once I get a picture of it I'll post it.
Total cost was $3. It will serve my purpose just fine.
If your looking to show-off the engine, the D-tec heatshield would probably look more profesional though.
98 SVT E0 T-Red E1 engine resonator removed K&N w/ MAF adapter 20% tint Ford Trans. cocktail Ford 9mm Racing Wires DMD
#640906 05/20/03 10:10 PM
gotta do what you gotta do. mine isnt the prettiest either but it serves its purpose!
#640907 05/20/03 10:13 PM
W3RD...made my own too,serves its purpose.....try painting it flat black(if you haven't already)looks alot more liks its supposed to be there when painted flat black....
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#640908 05/20/03 10:37 PM
I am planning on painting my heatshield black.
With the green plant pot, it looks like something that belongs on a John Deer tractor.
#640909 05/21/03 05:48 PM
Since it's a heatshield, wouldn't a lighter color be better (to reflect rather than absorb heat)? Or doesn't it matter in this case.
Doug 2006 Mercury Milan V6 Premier Dark Blue Pearl Former owner of a 2000 SVT Contour
#640910 05/21/03 06:39 PM
this is what im trying to find out how to do on my svt. What kind of MAF adapter do i need, what all do i need for this intake mod?
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
#640911 05/21/03 06:48 PM
Dude..go back thru the Duratech performance for the past 2 weeks, and its all listed there with companys and part #s..you can't go wrong!
K&N #3530
Any MAF adapter (BAT, KKM, Duratechperformance, PF)
Look in the classifieds/links section
#640912 05/21/03 09:35 PM
In the case of radiation from the sunlight, yes the light is attracted and absorbed in darker colors.
I could paint it white, but when I close the hood it will be dark no matter what. I believe the issue would be what type of coating or paint to use rather than what color to choose.
My K&N is not touching the heatshield, there is about a 3 inch gap all around also.
There is much speculation on what material to use also.
Some use plastic, some use aluminum and other metalic material to reflect the heat away from the filter.
#640913 05/22/03 03:54 AM
The darkness has nothing to do with it bro. If the heat shield is black it will basically hold on to any heat radiated against it; Causing it to heat up a bit, and thus the intake temp to be slightly higher. If however the shield is white, whatever heat gets radiated to the shield has a better chance of being reflected to the engine bay and not the inside of the intake itself. If you want, do a search for ??back body? or something to that effect. White may not look as nice but, it is the best solution. Insolating the hell out of it should let you pick any color you would like.
-2 cents
Canada = little France
#640914 05/22/03 12:48 PM
N
N
-2 cents
You are right about the issue of a lighter color compared to a darker color for heat radiation. But I think the effect of the color is minimal compared to the material the heat shield is made of. The thermal conductivity of the material is a more important issue. A metal will conduct more heat than plastic. Conduction: Aluminum > Stainless steel > plastic (e.g. polyethylene).
Reducing heat radiation and conductivity through the heat shield still don't seem as important as just blocking the hot air. If your engine sucks cold air past a hot heat shield (depending on the rate of air flow) I don't think it will have enough time to get hot before entering your engine. So in my opinion, I think the issue is just blocking hot air.
Just my 2 cents.
06 Mustang GT - stock 96 SE V6 5spd Midnight Red - 15.9 @ 86.8 150K miles Mods: Bilstein struts, H&R springs, Borla Cat-Back, Brullen y-pipe, Gutted Precats, SVT UIM+LIM+TB, K&N FIPK, , DMD, Magnecor KV85
