Page 3 of 3 1 2 3
Jon - NJNeco
2000 Silver Frost Cougar v6 MTX
Dyno Tested 173.6 whp - 161.2 wtq
Visit MaStaMooN.Com for Details! *Back up in a limited form*
I don't think there's any question of there being two types of throttle hang...one is the usual "Geez it takes forever for the RPMs to drop" which can be improved with the well-known TH fix.
The second, being discussed here, is the situation where RPM literally stick at 4,000 or so for several seconds, sometimes even rising while holding the clutch in. When this occurs, idle speed is usually abnormally high as well...often settling around 1200 or 1300 instead of the normal 750 RPM.
I think we could get faster action and more serious consideration from Ford if we pursue this with dealers as a safety issue...braking distances are significantly longer when the throttle is sticking open.
Mine was fixed for a couple of thousand miles by replacing the IAC valve, but it's started doing it again in the past few days. I'm taking it back to the dealer today.
Craig
99SVT black/tan
2725 of 2760
Rob R. Offline OP
Craig,
Can you tell what an IAC valve is?
Thanks,
Rob
95 Contour LX
Approximately 120,000miles
2.5 MTX
Red
IAC Valve is Idle Air Controller Valve... It controlls how much air enters your engine when you let off the gas (to keep it idleing). I have suspected this is my problem, but after hearing that people have replaced them and the problem comes back, I will not go out and buy one just yet.
Jon - NJNeco
Rob R. Offline OP
Hmmm, interesting. How much do IAC valves cost? Another thing, are you saying that initially the new IAC's solved the problem and then it came back? This might be important.
Thanks,
Rob
95 Contour LX
2.5 MTX
Red
It may.. it may not.. The new IAC fixing the problem temporarly might be attributed(sp) to disconnecting the battery for a lil while, which also seems to stop this problem for awhile. But then again it might not.. Maybe some wiring is causing faults in the IAC itself after awhile?? I really dont know.
Jon - NJNeco
I agree. It's hard to say whether the IAC is the problem or not. I had mine replaced in late March after complaining about sticking and rising RPM, which the dealer attributed to a "sticky" IAC valve.
About 2,500 miles later, the problem came back. The funny thing is, that with mine, it seems to get worse with time. By that I mean, at first, it'll do it once in a week, then it'll do it every two or three days, and now, about four weeks after it first re-appeared, I'm getting the sticking RPM practically all the time.
I took it to a different dealer last Friday, and of course, the problem was not evident. I did talk to the shop foreman at some length. It took me 15 minutes to get him to admit that it is not normal for a Contour or any other car to behave like this. (i.e., RPM stick for several seconds, sometimes rise, and idle is 500 RPM above spec)
As for disconnecting the battery to reset the computer, I've done that several times, with very inconsistent results. Sometimes it works and sometimes it doesn't, and when it does work, it doesn't last long, so I'm assuming that resetting the computer in this way is not making any difference at all.
I plan to return to my previous, usual dealer in the next week or so, and we'll see if they have any other ideas.
I can't say how p*ssed off this makes me. Aside from the premature wear on brakes and clutch, the excess fuel consumption, and the complete lack of driving enjoyment, I just hate sitting at a stoplight with my car roaring away at 3,000 RPM.
Craig
99SVT black/tan
2725 of 2760
Page 3 of 3 1 2 3
