Page 1 of 3 1 2 3
Rob R. Offline OP
I'm only getting the hang when driving the car and shifting - not when the car is stationary and I'm simply reving the engine.
95 Contour MTX 2.5L
95 Contour LX
Approximately 120,000miles
2.5 MTX
Red
Q
qaz Offline
Q
I wouldn't think so.
A bad TPS can, though.
Brian
TH is a known problem. (PCM programming for emissions - blech!)
There is a fix for it in the FAQ area.
Yes it can be much more pronouced while moving.
2000 SVT #674 - Check it out!
Q
qaz Offline
Q
I had pretty bad throttle hang and it went away when I replaced the TPS.
But in that case it had gotten worse than what would be considered normal for that car.
So if the throttle hang suddenly gets really bad it could be the TPS, but don't expect a TPS replacement to fix the normal throttle hang.
Brian
Rob R. Offline OP
I'm getting my new TPS tomorrow. Can someone tell me how or show me a link so I know how to change this bad boy?
Thanks,
Rob
95 Contour LX
2.5 MTX
Red
N
N
It's designed to throttle hang.
It won't do it while revving while idling.
It's for emissions control that the engine takes a few seconds to come back to idle speed when driving...
BUT it is a major pain in the but!!
E
E
What are some of the symptoms of the TPS being bad? I can't keep dumping money into this car.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
Rob R. Offline OP
Hi,
This is not your classic throttle hang. I already have the new black tube configuration in place. This symtom is car in motion, press the clutch and the rpm's not only hang but increase slightly before they come back down. This never ever happened prior to the mtx tranny work I had done and now it's just huge. I REALLY don't think it's the classic throttle hang problem, as I said I have the upgrade in place. Another symptom to a bad TPS is throttle hang at highway speeds. It's a cheap sensor to purchase and I'll let you know what happens as soon as a get it changed.
I still need the install information.
Rob
95 Contour LX
2.5 MTX
Red
Rob R. Offline OP
I'm looking for any information on replacing my throttle position sensor. Can someone let me know?
Thanks,
Rob
95 Contour LX
2.5 MTX
Red
Rob,
What you descibed is the classic Throttle Hang to the "T".
Search for other decriptions of Throttle Hang and you will see you are not alone.
My Duratec ATX will do it, if I shift into N while coasting.
You would think it would go immediately to idle,
but it actually rises and then falls slowly.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Page 1 of 3 1 2 3
