Originally posted by zetechfun:
are you stock if so sounds like the computer rev settings if theres no other sounds or drop in gas milliage probably just one of the neat computer things ford does. I put a JET chip in mine when i got it you will also need a modified air intake(ZX2)
:rolleyes: Oh man you are hopeless...
Like stated. Your intakes definitely need cleaning (even if not the cause they can sure use it
Something else I would check is the cable to make sure it is not broken. You can do this easily by pulling on it where it is exposed right by the secondary linkage.
Also pull the electrical connector off of the IMRC and clean/check the contacts. (both ends) Apply some dielectric grease to the plug and re-install it.
