Posts: 218 |
Ok I am putting a after market open element air filter on my 2.5 contour. what is that sensor that plugged into the air box,and where should I put it to make my car work again why does it prevent my car from working. I appriciate any help asap please !!!! thank you DJ
http://www.pbase.com/contourconcepts/contourconcepts Motegi rims and lugs, Custom decals, soon I will have custom air brushing and corvette hood scoop, custom interior pieces and fiber glass enclosure in the making. kicker 900 watt amp w/2 kicker comp vr subs, pioneer xm radio, functioning euro antenna, clear interior brake light,CAI, blue bulbs and apr spoiler. Nitrous kit sitting in garage waiting to be installed, along with msd dis ignition wich is to be put on by MSD tech's who insist it will work. waiting on manual tranny and svt conversion parts. 2.5 v6 (DJ Says) "Hey our Contour may not be the quickest car on the streets but its been proven to whip a few of those Celicas here and there." (Lil Timmy Bojangles Exclaims) "EVEN THE ONES WITH THE CHROME EXAUST TIP AND THE 6 FOOT WHALE TAIL??""" (DJ Responds) Yes Lil Timmy ..Even Those Ones. =oÞ
Posts: 218 |
hate to push but I need my car lol ..Im sorry
Posts: 14 |
that is your air intake temperature sensor. What I did was put a hole in the flex hose on the flat part right next to the throttle body. Then I just wedged it in there.
Posts: 218 |
Thanks ..anyone else have any other suggestions or confirmation about the flex hose idea... not that I dont trust you I just really need to make this bad boy work
Posts: 218 |
OK I installed the sensor in the flex hose and nothing ...didnt wanna run at all ..it would start but shut down 2 seconds later. I got conserned and put the air box back on and it worked fine ...while it was running I took out the sensor and looked at it , blew on it .. and everything else and it never skipped a beat ..why doesnt my car work with a intake>?
Posts: 14 |
did you buy your adapter from ebay. If so does it have a restrictor plate in it? The one I bought had one and my car wouldn't run good with the open air filter on it. I had to dremel the restrictor plate out, then it worked fine.
Posts: 5,805 |
Any bits of packing/cardboard in the new air cleaner???
Posts: 218 |
Yeah the plate was sorta like this
________ ]0___ o ] ] } } ] ] ---- ] _o_____0_
is that really resticting air flow so much that my car wont run? No paper or cardboard of concern, perfectly clean and air tight yes off ebay
Posts: 14 |
I have no idea what your pic is showing me, but if it has a square hole inside the round part then yes. It doesn't allow enough air to get to the mass air flow sensor. It is billet aluminum so it is very hard, so use a drill to get as much of the restrictor out, then dremel it so the air has a good path of flow. Then put it back on and see if it works. Did you have to drill new mounting holes in it because they were in the wrong place?
Posts: 218 |
yes as a matter of fact I did however I know I have no leakage because the holes are far enough away to where the dont interfer with the actual intake hole. Could this really make that huge of a differance though? I mean come on it is still 3 inch by 3 or so ...wouldnt the stock air box be more restrictive than that?
