Posts: 548 |
was just reading up on the TH fix
what exactly does this fix?
I know if i step on the gas hard, and lef toff shortly after the shift is really hard (ATX) cuz the revs are high
is this what it fixes?
98 contour gl, v6 auto
01 explorer sport v6 auto
2001gtp AT gmail DOT com
Posts: 1,012 |
This will fix that problem. Also, it will fix the "moosing" problem. If you don't have this, you will, and it sucks. The TH fix is the best mod you can do, and its free! Do it, you will notice a considerable gain in shift performance.
Posts: 4,714 |
It sounds like you're also experiencing the "bang" shift as well. There's a thread in the Transmission forum about how to fix it, but basically there's an updated TSS (Turbine Speed Sensor) that you can get for less than $25 that will prevent the ATX from bang shifting when you let off on the accelerator right before a shift. The part is cheap and the procedure is easy, so head over there and take a look. Don't forget to get the correct part number for the new TSS, which is in the thread.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 548 |
what the heck is moosing?
what exactly does the TH fix, fix? or cure? or change?
i just fail to see how it imroves anything, maybe im not understanding something right?
Posts: 4,713 |
Moosing is a loud howling sound that can often occur after putting an open element air filter in our cars. Haven't heard it, but I'm sure it sucks. TH Fix - In a MTX: when shifting the RPMs will "hang" as you push in the clutch and reach for the next gear. It's only mildly annoying most of the time, but it actually makes for some rough shifting at high RPMs. In an ATX: I don't know of any other benefits other than killing the moose.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 1,831 |
The moose affects cars with stock air filters/boxes as well. Believe me, you'll know it when you get it.
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
Webmaster
Webmaster
Posts: 1,359 |
TH == Throttle Hang
Does that make sense now?
-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
Posts: 548 |
know what it means... but ive never noticed it on my car or any other contour
then again mine is an ATX which by the sounds of it wont benafit from the th fix
Posts: 1,616 |
Putz,
TH is when you're accelerating...push in the clutch to shift, let off the gas..and the revs kinda hang up there before slowly coming down. Kinda like an 80's smog car.
Moosing...is an incredibly irritating and loud sound that is very apparent with an open filter. You're accelerating...everything sounds cool with your open filter, and as soon as you let off the gas...this moosing or moaning at just the right pitch which is irritating as hell comes out loud. Also happens when the AC or defrost gets turned on.
The TH fix will alleviate both in one fell swoop. And at <$1..its cheaper than a new AIC (or is it IAC)....
Posts: 3,076 |
Putz has an automatic, he doesnt have to deal with throttle hang. And The moosing I've only noticed in cold weather. And yes you'll notice it when it happens. Sounds like a fog horn. Or in canadian terms.. it sounds like a hockey arena goal horn under your hood when you let off of the throttle. but again, I dont know if this happens with automatics. I paid 27 cents for my TH fix.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
