Page 3 of 3 1 2 3
Ford has a factory recall on the 95 V-6 Contour for the Main Catalytic Converter and the pre-Cat/ exhaust manifold assembly replacement. So go in there first and get it all replaced for free. Before, mine wouldn't pass either (when used to live in Arizona State). It's because the Cat serves to convert Carbon Monoxide into Carbon Dioxide and also burns the excess unburned Hydrocarbons from combustion. So then after you get the Cat replaced, if it still wont pass, you run the tank almost empty and then put in a quart of straight alcohol into the tank, right before you go have it tested, and it will probably pass (I used to work at a auto shop/ vehicle inspection station in Utah that always did this trick to get marginal vehicles to pass). If it still wont pass, then you can always get a PO Box in my town in NW Washington, so you can license your car here since we don't have inspections smile
'95 CONTOUR SE
-Enkei 16s
-Porsche944 Exhaust tip
- Audi xenon projector headlights
-Peterbilt 30" air horns
-mp3 Aiwa headunit (150 songs on one disc)
-dual 10s
-soon to have LED tailights (real kind, not just gay bulbs)
-That's it for now
9
9
RXP is a fuel additive that seems to help. My 1970 Buick Skylark w/ a 350 was running very very clean when I used it..>
I've used it on all my cars since...
Try it out, it should help.
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
Page 3 of 3 1 2 3
