Page 4 of 6 1 2 3 4 5 6
You know Alan.....even with 163,000 miles on the Shark....I'm so tempted to take out a $5,000 loan at this point. Hmm....first 95 turbo???
2000 WS6 Convertible A4 13.11 @ 107.5 with a lid, Ram Air and LTs Gone:95 Mystique LS Young America edition V6, MTX 15.6 @ 91
F
F
forget the 13.8 time.. I'm impressed most by JUST the 5psi
Eric
W
W
I'm running 93 octane daily....
I do have the SF intercooler....
Keith/Chris sent me out the hottest program(timing wise) to date due to the daily availability of 93 here in Florida. But after a few weeks of driving and a turn of the boost controller, I found that 7psi with my current chip is just to much. I attempted to tune it in with my Apex'i, but no luck, plus I would rather have a good base tune in the chip as a precautionary device.
Chris has already begun working on a new timing curve that supported 240whp at 6.5 psi.....I can live with that! I previously turned 230 on 5 psi, so I may be missing a couple of whp due to the couple degrees less timing, but it will be able to support more boost.
I will be purchasing drag radials, and I will turn the boost up marginally, and periodically..
Also, one cannnot compare system to system by psi levels, as different compressors have differnet CFM at the same psi setting. For instance: 5psi on my T-28, may have a similiar flow rate to a 16g at 15psi. So the Vortech 10psi, and the SF T-28 5 psi are "apples to oranges".
I do commend those that have run well on nitrous, but what happens when you don't have a fill station? I continuously run strong, while you fall back in the pack....Brian Earl Spilner....you serial killer from Arizona! J/K
2002 ZO6...462whp/410wtq pretty darn fast!11.70 @ 122 silver/black 2006 Trailblazer SS(wifes car) silver/black 2000 SVT-Turbo-sold silver/blue #1699/2150 13.83 @ 102.82 on 5psi 13.51 @ 107.56 on 8psi
Dude....you're killing me with the quotes!!
E
E
Awesome! That wasnt even your best trap time of the night, so if you had stuck it out a few more runs I bet you would have seen even lower 13s. Impressive too considering the temp and humidity.
Since some of us dont look at the FI section or anything, can you give us breakdown of what the setup is exactly and approximate cost?
00 SVT Contour: SHM LT headers, LSD, Spec Stg 3...dyno:190.3whp sold 02/04 04 Subaru Baja Turbo 5-spd 00 Camaro SS 393cid: 510rwhp/469rwtq, 11.16 @ 124.95(hit 1-2 limiter) www.erikz.org
wow that is seriously very quick. Congrats on the nice times! Not bad for a FWD car that wasn't madeto be fast straight line, huh? I could see low 13 sec flat, possibly a 12 sec in the future with more boost, drag radials, and more practice. Some pretty darn good launches as well! Congrats and live it up.
GO NOW AND SPEND SOME MORE OF YOUR MONEY AND PUT UP BETTER NUMBERS TO MAKE ME EVEN MORE JEALOUS!
99 Mystique LS T-Red ATX Duratec Mods: Hella stereo Mods K & N air filter w/intake pipe www.sounddomain.com/id/jongordo8
Standard Street Flight Kit includes (parts can be upgraded):
Garrett T-28
Dual ball bearing liquid cooled
Headers
321 Stainless headers, 304L downpipe and intake pipes
Downpipe includes flex and 3" high flow cat
Filter
7" K&N
Intercooler
Liquid to air
Blow Off Valve
Turbo XS types S
Wastegate
Tial 35mm divorced wastegate by Garrett
Heat Exchanger
8 pass 1/2"
Reservoir Tank
4 gallon aluminum reservoir tank, with aviation style lid
Intercooler pump
198 gph
Injectors
6 24# Ford
Spark plugs
6 NGK
Engine Management
Custom dyno tuned Street Flight chip
Ventilation
Catch can with breather
Battery hold down kit
0 gauge battery line, eyelets and hold downs
Misc.
All silicone for intake, all bolts, oil lines and fittings, brass, vacuum tees and plenty of hose clamps.
Total cost is $5000.
Y
Y
Originally posted by BlackCSVT:
Nice times. I am waiting to see how SVT NAte will run with the 3liter , I/E, Fidanaza f/wheel, grizzly, 75 maf,24 inj,svt cams,short throw,optimized tb,and a 125 shot. We should be hearing vroom vroom this weekend. Then we start my car=)
Are you just not putting in the Grizzly Clutch? If so, send it back and get a SPEC. I had the Grizzly and after 8 days of having my 3L Hybrid the Clutch Disc came apart and one of the springs came out. It's basically a stock clutch which will not hold that power.
I thought that I had read something about Street Flight offering a flip chip, if they do I would think you would want to keep your present program for the track and something with less timing for the street. When you arrive at the track just make sure that your low fuel light is on and buy 2-3 gallons of race fuel and crank up the boost to 10 psi.
99 T-Red SVT #1634/2760 K&N filter Aussie Intake Pipe Pro-M 75mm & Optimizer B&M Edge Shifter Quaife LSD Borla Cat back MSDS Headers/sho-shop Y-Pipe Dynoed at 184.2 HP & 157.2 TQ 14.53@94.15
Are you sure the Cobra was spraying? (BTW there was no 2000 Cobra's) They run 13.5 stock. It could've been a "poser" GT with a Cobra body kit. They push 272 HP at the wheels and weigh about 3400 pounds.
Mazda 6S, V6, Speed Yellow 5 Speed, Sport package Bose audio Painted 'stash and HIDs! w/Injen 1/4 14.750 @ 94.94 Former car: 99 Contour SE Sport Black MTX V6 SVT plastic... 1/4 - 15.012 @ 90.58
Moderated by  mbb41_dup1
