Posts: 219 |
Same here. I've had no major problems with my Contour either, and have put a hard 60,000 miles on it.
I only hope my next car can take this abuse and not break down!
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 1,559 |
Your car probably needs the wiring recall done. Have the Mechanic take the battery out and look at the wires going into the underhood fuse box. I bet he finds some bare wires. I doubt it's the Alternator or the car wouldn't have run on the way to the gas station.
Posts: 12 |
These contours have the same problem as some Mazda's. Check and CLEAN engine to bnody ground straps thoroughly. If you get a bad connection you may get all lights etc on but not enough amps to crank that starter.Remember a starter is a series wound motor and just about short circuits your battery when starting so make sure all battery and ground connections are clean..clean..clean.!!! Quick alternator check.Run Engine check voltage at battery terminals. Should be about 13 volts or higher.Don't own a voltmeter? Then pay a good auto electrical guy to figure out the problem!!
gleschu
Posts: 620 |
Yeah, that can happen -- my old Mazda 626 wouldn't start a couple of times and the problem turned out to be simple tarnishing of the end of the main cable to the starter. A little sandpaper on the metal and it was fine.
Unfortunately I'd already paid for a new starter.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 68 |
I am going to agree with Lee here. There is a recall for the wire harness and I just had mine changed out. Check it out. There were several visible wires and cracking insulation, but then I looked at it once they pulled it out and I was lucky that my car didn't go up in flames one day. I also consider myself lucky that the only "non-maintenance" work done was having to change out the four motor mounts and a belt tensioner. *Crossing Fingers* I notice that so many people here are having A/C problems, and again, I am fortunate since I NEED A/C in New Orleans. I LOVE my car. I have since the first moment I saw it, and I still owe $3k. Yeah, they made a killing off of me. :rolleyes: Good luck!
'95 GL White K&N *New Wire Harness* ;P Pioneer front spkrs, Infinity rear, and Kenwood 320w amp installed YAY! I'd like to give a shout out to audio forum-esp. archives...you guys helped more than you know..THANKS! No more mods for now--just hoping she stays well. 78K and still kickin' it. neworleansgrl26@yahoo.com
Posts: 116 |
You can't really blame it on Ford that you went and put in all this high watt stereo equipement in without upgrading the charging system, and expecting it to all work fine forever. You must remember that when you are overtaxing the charging system with the hi-watt stereo blaring loud, then you must turn some of the other accesories off during that time so your alternator isn't full fielding for long periods. Because doing that will burn out the diodes in ANY alternator. If you want to be able to turn all your accesories on high full bore along with your stereo cranked, then you need to put in like a 150-200 amp alternator so your charging system wont be running at 100% all the time. If it wasn't you doing that, then it was probably the previous owner who did. My '95 Contour has 110,000 miles on it, all systems still pulling strong.
'95 CONTOUR SE -Enkei 16s -Porsche944 Exhaust tip - Audi xenon projector headlights -Peterbilt 30" air horns -mp3 Aiwa headunit (150 songs on one disc) -dual 10s -soon to have LED tailights (real kind, not just gay bulbs) -That's it for now
Posts: 64 |
damn pricy cars i got a 99lx w/ 65000 miles for 4000 fully loaded minus leahter and sunroof
99 Silver frost Contour LX ztec.. 35% tints all around.. Aiwa Deck w/ Infinity reference all around......
Posts: 704 |
98 SVT's can suck too ya know...
Originally posted by 99SESPORT: First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off... And sitting there telling him politely
"Please let go of my nuts, sir?"
Posts: 29 |
Each day brings a new challenge with my SVT. Everytime I get rid of one bug, another pops up! I get as pissed as possible with my SVT. I walk away from it in disgust, wondering why I ever bought the used-up POS. Then, I drive it and fall in love all over again with its' superb handling and superior acceleration. It shifts like a dream, the clutch is positive; it responds to my every desire with all the heart it has. Ahh, if I could only find a woman to cradle me with the same tender but secure grip of its' seats. Only a faithful old dog could ever match my SVT's desire to please me! John 98 SVT
John Black '98 CSVT #2000 of 6535 Sometimes good, sometimes bad Sometimes hate it, mostly love it No mods other than 225/45-17 tires
Posts: 1,537 |
My alternator is starting to give me warning signs also. I got on the throttle a few days ago, and as the RPMs rose up over 5000 rpm, the battery light slowly went from dim to bright as the RPMs passed 6000. When the RPMs went back down the light went off and the voltage returned to normal.
Too bad I can't replace just the brushes and regulator.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
