You might not have a problem. Once tires start to wear in an unusual pattern, they usually continue to do so even after alignment has been corrected.
Anyone worth his salt doing an alignment knows how to inspect for things that would make the car non alignable, such as worn bushings, tie rod ends, ball joint, etc. You can hope that they looked for such problems.
I have found that our cars seem to have the front toe change from normal use so that the toe out increases over time, especially with wide tires like the SVT has. As a result, my preference is to set the front toe as close to 0 as possible while still being very slightly toed out and the rear toe as close to 0 as possible while still being slightly toed in. This way it is not only stable when first done, but will take longer to drift to the point of causing tire wear. In other words, the alignment will last longer.
