hi,projectSHO89:
My A/C clutch just refused to kick in
when I switched the knob to A/C. I
finally found that the yellow R4(compressor
clutch relay) doesn't receive a '+' signal
when I turn on the A/C. If I bypass R4, the
clutch is engaged and A/C works fine.
I don't have a service manual for my
contour 95,GL,V6,ATX. Could you help me
to have a look in that manual and give
me some suggestion?
btw: recently recharged R134-a, so the
pressure inside should be OK.
Thanks!!
