Janine Offline OP
What is the correct thermostat temp for the '96 V6?
I just noticed that several online stores have a 180 degree Stant stat listed for this engine, but
other stores w/other brands, as well as the Motorcraft site, have a 190 listed.
I checked at work (Advance), & the Stant catalog has 180 listed as original equipment temp. But Stant only makes a regular stat for this engine, & I would rather have the SuperStat.
'96 Contour SE 2.5L Duratec V6 MTX Teal
Purchased New - 9/95
43,000 Miles - I Know, I Need To Get That Water Pump Replaced!!
K&N Air Filter/K&N Oil Filter, Castrol Full Synthetic Oil - Switching to Mobile 1
Advance Auto Salesperson (When Not Working At My Reg Job [Wildlife Biologist])
(Hey, Why Not - I Get A 20% Discount & Have Access To All The Parts Catalogs!!!!)
hell a lower degree thermostat shouldn't be a problem should it
especially with summer coming
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
H
H
Why would you want your engine to run at lower than its recommended operating temperature?
a. lower mpg
b. higher emissions
c. poorer performance
d. so I'll have more time to react when wp fails
e. all of the above
stock CD on LS, cass on LX
4 wheel discs on LX only
Stock V6 thermostat is 180 degrees.
You do not want to install a 195 degree unit.
2000 SVT #674 - Check it out!
Janine Offline OP
"Stock V6 thermostat is 180 degrees. You do not want to install a 195 degree unit."
Just curious, & I'm sure you're right, but how do you know this? I haven't had my old one out yet, so I don't know what temp was stamped on the original - maybe you have? (Are Motorcraft stats stamped?)
The Ford Shop Manual (page 03-03-24) says that it starts to open at 183-190, & is fully open at 210. Haynes manual says starts to open at 189-194, fully open at 216.
The Motorcraft stat for this engine, #RT-1104, is listed as a 190.
So I'm confused.... confused
Ford Factory Service CD states it. I ran across it when going through them. This was for the 2000 model year.
180 degrees for V6 & 192 for I4
It also lists pretty close to the same specs you list for the Ford manuals you posted (was 180-184 opening IIRC - it's been a while)
Either way you do not want to go up in temperature to a 195... You want to run as cool as possible and still be within the computer's operating temperature.
Is it possible that there are different thermostats for different model years?
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Just changed water pump and thermostat in my 2000 SVT. The Thermostat that came out said it was a 188 degree. I replaced it with a 180 which I checked before I put it in and it opened a little hotter than that. I don't think the 8 degrees is going to make that much of a diffrence. Got a 192 -195 for my wifes mystique for when I do that system.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
Rule of thumb, as long as you are within the calibration perameters of the EEC, running coolant cooler = more power, running slightly hotter=better mpg economy.Example , most electric pump controllers can be adjusted for temp.....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
F
F
Isn't there a spec as X temp it starts to open and a higher temp when it's fully open?
Paul
