Page 1 of 6 1 2 3 4 5 6
#631427 05/11/03 04:53 AM
juices Offline OP
what is the top speed on a stock contour 98 duratec with a chip?...
98 silverfrost contour se duratec mtx eibach springs koni struts K&N P-Flow ford racing plug wires
#631428 05/11/03 04:55 AM
i think without the governor on the non-svt's its somewhere around 135 mph iirc. and with a chip, it probably wont be much different.
#631429 05/11/03 05:29 AM
CEG road warrior
CEG road warrior
140 in my Zetec. My speedo is about 5-10 mph off so between 130-135.
#631430 05/11/03 07:53 AM
W
W
Yeah but your muffler has got to add like what 20 hp minimum, the sound alone is enough to get you too 60 no problem.
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
#631431 05/11/03 09:43 AM
I
I
is that chipped?
mine has never went over 112...and thats without the speed limiter kicking in(I think)...how long does it take to get that high
I was expecting the governer to push me back down but it doesn't...its just stays at the same speed
hmmm...
#631432 05/11/03 01:04 PM
112 is the governed speed. get a chip to go faster or always drive downhill....
2005 Focus ST
#631433 05/11/03 06:39 PM
juices Offline OP
can you get rid of the governor without a chip?
#631434 05/11/03 06:44 PM
i think there is a way, but it causes you to have no speedo, so what's the point as you'd wouldn't know how fast u'r going.
#631435 05/11/03 08:48 PM
Go find out...
98 3.0 svt: Sold
#631436 05/11/03 10:55 PM
if you stick it in nuetral going down hill it will go over the govern speed, otherwise is uses your engine to hold you back. I have tried it before, but be careful when in nuetral switching back into gear, make sure you slow down first.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
