Posts: 1,493 |
Just an FYI, all Contours are R-134 refrigerant, not R-12 AKA "Freon". If your getting a kit, don't mix R12 and R134!
BTW: Freon is a brand name, like Fritos.
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 339 |
Mine does the exact same thing, revs up and down, so just recharging wil make this go away..
Also when the ac is on and im driving the temp meter is near or on the white area, or just before the N, does this have anything to do with that???
Matt
'97 Pumice Zetec Sport- Superchip/Apexi DTM Tip/KKM/blue lights/removed door dings/De-Badged/ford racing 9mm-blue/Custom Interior/indiglo gauges Audio -3 JL Audio 10s/-2 kenwoods amps/-JVC cd head unit (with 12 disc changer)/-6x8 pioneers http://www.geocities.com/mattbchillin
Posts: 2,523 |
2000v6SE: Thanks for pointing that out. I forget R-12 still exists sometimes. Plus, I didn't know Freon was a brand name MB: Yes, a recharge should do the trick as long as you don't have a leaky system. As far as your temp guage goes, when the A/C is on it forces the engine cooling fan(s) to stay on. This keeps the engine at a lower temperature. It used to be that running the A/C actually made an engine run hotter because the fan was belt-driven and there was only one. Now, there are usually two and they are turned on/off via the car's electronics. My car always runs cooler with the A/C on.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 59 |
D Davis Yes, it needs a recharge. It isn't hard to do - I've become quite familiar with the process since my A/C has a leak (hope to have that fixed by next month). If you need simple directions, let me know and I'll help ya out. I could use al the help i can get to recharge this so it will stop reving up and down
1996 Contour GL Zetech no add on's just stock a plan jan lol
Posts: 59 |
Hey D Davis I thought you were going to help me out with the A/C recharge? email me at bigguy4963@adelphia.net i really nned to get this fixed ASAP it's driving me nuts
Thanks
Sam
Posts: 345 |
My compressor was fast-cycling indicating low charge. One 12oz can of R134a has it blowing ice cubes again. Only take a couple of minute to do. Add via the LOW pressure port near the battery side of the A/C line running across the radiator. Start car, turn A/C on MAXIMUM, connect charging hose, place refrigerant can in a pan of warm water and keep can upright so the system sucks gas - not liquid refrigerant.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
