Max A/C is the only setting on the car that uses recirculated air. That rest pull in air from outside the car, but they hardly push out any air at all. We are having very wet, humid weather, so I can't de-fog my windows. The car is basically undrivable because I can't see where I am going. The door that opens and closes to pull in fresh air is malfunctioning. I was just wondering if anyone knows where this door is at, or have had this same problem happen to them? If so, what was the solution? Thanks guys.
1995 SE
Mods-Resonator gone, glasspack in place (It sounds good, try it).
Cracked secondaries, TPS Mod, Removed Intake resonators.
Future Mods- SVT exhaust (Wanna sell yours?) and window tinting this summer. More for later.
Its my daily driver that I race on the weekends.
Check out alldata.com for the blower resister recall. That might be your problem for the low air speed. My fan only worked on low and high before I had it fixed.
If the inside/outside air switch is working part of the time (on Max AC but not on defroster), it sounds like a resister problem again. Is your A/C charged and cold? Maybe the charge is low.
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
Might also be a badly clogged pollen filter.
I understand you DO get outside air on the lower settings of the fan, right? Just not very much. When the cabin air filter is clogged you get problems like this.
The filter should be replaced, not cleaned.
To access the filter iirc you have to remove the panel in front of the windshield, passenger side. I believe you have to move the windshield wipers to the up position and turn off the ignition to be able to access everything.
Search brought up these among others:
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=006690
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=2;t=002557
hth
Joerg
Joerg
Thanks alot guys, I gonna try both of these. Thats why I love the forums. I'll keep you posted.
1995 SE
Thanks again guys, the filter did the trick.
1995 SE
My Contour did that too. Especially bothersome when the windows would just fog up and you couldn't drive. Checked and cleaned my pollen filter. Still no air. Then I disconnected a vacuum actuated air valve under the dashboard (above gas pedal area), and moved the flapper valve the other way, the problem was cured. But about a year later, I got a RECALL notice from Ford saying they fix that problem (faulty actuator) for free! So while your there (only go to a reputable Ford Dealer), have them service all of the other recalls on the car (including the cooling fans and fuses that might burn the car down if not done)
'95 CONTOUR SE
-Enkei 16s
-Porsche944 Exhaust tip
- Audi xenon projector headlights
-Peterbilt 30" air horns
-mp3 Aiwa headunit (150 songs on one disc)
-dual 10s
-soon to have LED tailights (real kind, not just gay bulbs)
-That's it for now
