keroy Offline OP
I've done much reading about sub-frame failures with the "Aussie" bar, has anyone out there had this experience with the big BAT bar?
'99 CSVT,#79/2760,Black/Blue,H&R's,BAT struts,BAT"22mm" rear sway bar,poly bushings,K&N RU-3530,DP MAF adapter,Magnaflow 10425 Res.,Tranny cocktail,FSVT rims, Falken Ziex 512 235/45ZR17's, SS brakelines.
Let's just say that when I pulled off the BAT bar to install the Aussie Bar, part of the subframe on the driver's side that holds the stock swaybar mounting bracket tab was bent slightly. Who know's what would have happened eventually after another winter or two of salt? Actually I do know and it did happen to me after I installed the Aussie bar.
The moral of the story is that with anything above the stock bar, you should box in that area of the subframe or risk the consequences of a torn up subframe.
George Hodge New: Volvo S60R Old:2000 SVT Silver Frost 1188/2150 DMD, 75mm Pro-M, HPP rear strut tower bar Aussie 24mm sway bar (with boxed in subframe) BAT European Handling Kit, Brullen Y-pipe Performance Ford spherical bearing end links
1
Now I know why everyone is selling them on the classifieds
Are you guys talking about the Front or rear bars. I was thinking of going to the Bat 22MM on the rear.
95 Tour ATX Zetec EGR Block OFF Polished TB Polishe Vavle cover Energy suspension Greaseable sway bar bushings Front and rear Red interior lights 1/2 done Home made short ram intake Custom Grills Watch this space grow
keroy Offline OP
Definately talking about the rear. It's looking to me like the problem is not the bar, but rather , Ford's cheap way of doing things. The problem is in the swaybar mounts on the subrame. If your going to upgrade to any kind of heavier sway bar, these mounts should be reinforced. They're just not up to the heavier loads of a larger than stock sway bar IMO.
I have to crawl under to see for myself, but is the mount and the subframe area need to be beefed up?
I did a ton of subframe beefing as I had a '96 Grand Cherokee with a huge custom lift and running 35's, built V8, Dana 44 and 60 axels w/ 4.11 gears & lockers and rock crawled the ISH outta it, and those aren't kind to a weenie unibody like a ZJ has.
Hmmmmm, I wonder if I produced a "bolt-on" brace/mount for big sway bars if anyone would want one I'll have to check things out and come up with a design.
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
I've repaired many rear subframes. I speak from experience when I say, if you install a larger rear sway bar failure of the rear sub is INEVITABLE! The rear sub is underdesigned/engineered/fabricated. An extra 1-1/2 of weld per side would have helped immensely. Ford likely designed it to last through the warranty and that's it. They get a bit rusty, weaken and then whammo. We now sell reinforced rear subframes on an exchange basis. Our buttress plates DO NOT adversely affect the rear suspension geometry like the Aussie plates do, but they require the sub to be out of the chassis for install. This is important if your car is lowered. Otherwise, expect the dreaded sway bar "clunk".
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
b0x @dm1n
b0x @dm1n
Brad,
I have to disagree. I think Ford designed it work with a stock sway bar with lots of give. They were never designed with intention of a stiffer bar. Yuo don't here of many people ripping factory bars out and thicker bars are exponentially stiffer not slightly!
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
H
H
Cost and core price?
I ripped my rear sway bar off at SZ2002.
Sold 1998 Contour LX 13.868 sec 1/4 mile time. Two years of rental cars, seriously. Holding out for 07 Cobra Mustang.
W
W
Brad, good to hear from you!
I use the 22mm bar and I heard mine pop just sitting at a stop light about 2 months ago. I just unbolted it, straightened all the brackets and welded it back up with my mig welder. The welds make the section of metal a lot stonger so I hope it holds this time. But I do know what you're talking about. The metal is soft and has a lot of flex in it. It took about 1 year of driving with my sway bar before mine broke. I think one side broke first and the loud snap that I heard was the other one letting go. Scared the crap out of me because I thought I got hit with a rock or rear-ended or something! There was a car rolling up behind me when I heard it but he was too far back to be suspect. I just pulled over and looked around the car scratching my head and went home. I must have drove on it two weeks before I noticed it when I was checking my exhaust pipes. I really made the handling feel "squirly" in higher speed turns.
Tom
