Well AAmco recommends that I replace my Engine mounts. They can do it for a total of $750.00. I did a little research to find out why engine mounts/ATX mounts cost so much to replace and this is what I found out on the parts side.
MOUNT, Contour, Mystique, Right - 2.5L 95-97 $188.29 $150.63
MOUNT, Contour, Mystique, Left (Front), Auto Trans - 2.5L 95-97 $071.38 $057.10
MOUNT, Contour, Mystique, Left (Rear), To Crossmember, Auto Trans - 2.5L 95-97 $092.87 $074.30
MOUNT, Contour, Mystique, Left (Rear), To Fender Apron, Auto Trans - 2.5L 95-00 $111.59 $089.27
These above quoted prices comes from fordpartsonline and not from AAMCO for they did not give me an itemized estimate for this work just a grand total!!
Using the first figure from each mount listed above the four mounts total $464.13. Then subtract 750 from that figure and you get $285 for labor. I guess changing mounts takes a bit of time.
This morning I was going to drop the car off at AAMCO to have them do this work but just 100 feet two store from the AAMCO drive way I got side swiped and am now having the driver side review mirror replaced at my GEICO direct repair shop. Hmmm is this an omen or what. Guess I should not replace those mounts!!
Well is $750 too much to have the engine and ATX mounts replaced. The AAMCO tech did say that he heard a bump while testing the ATX that he attributed to weak mounts for he even said that the rear mount was very bad.
So I guess some time this summer I will have the mounts replaced!
