Is this a cronic problem with the CSVT?
I've owned two CSVTs and in both of them, the front right wheel bearing went south.
Why? Too much torque in the short shaft to that wheel?
Is this a cronic problem the Ford ought to be recalling? Would a LSD prevent this?
thanx...
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800
KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
Its a common problem...gets worse if you run incorrect offset aftermarket wheels or are very low.....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Thanx Terry.
Reliable info, short and sweet.
I appreciate it...
laugh
I own two 98's and both had to have wheel bearings replaced. There are four other guys I work with that have Contours and they all had front wheel bearings replaced. That seems like a extremly high percentage to me.
9
9
You may definitely want to look at the recall history. My 95 Contour SE had the wheel barings recalled. Mine left was recalled, andI just had the right one done at 168K....not bad.
X
X
What's the recall #?
Rob98CSVT897
Member # 3123 posted June 10, 2002 12:14 PM
thanx...
LSD would prevent you from noticing it, but as soon as it wears off, the problem would still be there and you would wonder if walls really can talk.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
An LSD will do nothing to improve the hub bearing issue, the two components do not affect each other at all......
V6 MTX
N
N
Yeah, I have a funny sound coming from the front, I thought it was a bad tire, but it sounds like "whump, whump, whump"
I do have aftermarket rims, I wonder if that is the issue.
How much to fix???
tnt Offline
I also have weird whump sound from the front of the car. I wonder if someone can explain how long wheel bearings are supposed to last? and how can you tell if you should replace them. what are the symptoms?
thanks! wink
1997 Contour SE
