Posts: 134 |
ok when i open the windows and roof....driver side gets extreme heat from the pedal area. i have a stereo, so the power wire is through the firewall. but i honestly don't think that that much heat can get through. Is anyone else haveing this prob???
95'contour se painted interior/calipers 220wt.3-way door speakers hyfonics 100x2 amp w/audiobahn 12'subs no performance mods
Posts: 1,537 |
Does this heat rush last only a few seconds ?
If it does, then it is just the hot, stale air, from inside the HVAC box, getting sucked into the car, when the interior hot air exits through the roof and windows.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 3,567 |
if you are concerned about the heat escaping past the hole the wire runs through, seal around the wire with some silicone RTV. A general purpose or clear RTV should work.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 134 |
it's weired, i don't think that that much heat can come from the little hole even if i didn't have it sealed(the insulation covers everything but the wire). the heat last until i step out the car. and it's only on my side.
Posts: 1,040 |
I also find the driver's footwell warm (although not extreme) and wish at times for the old style floor vents on the kick panels, which went the way of the dodo bird with a/c. Unless the hole is particularly big I doubt that's the problem, unless you just started to notice it with the wire installation.
In hot weather I usually keep the blower on floor and the speed one up from slow when driving with a/c off.
There is always the possibility that your catalytic is running hotter than normal.
Posts: 134 |
when you put the blower the blue section, it doesn't automatically set the a/c on?
Posts: 193 |
nope, you gotta set the knob on the left to a/c or max a/c
96 Contour SE, MTX 2 Pioneer 12"s in a bandpass box 2 5x7 Pioneer Plates 2 Stock Speakers 600 watts of blistering radioshack power
Posts: 3,419 |
The heat you feel in the driver's footwell area is probably radiant heat from the trans. That puppy gets HOT when you drive.
Posts: 134 |
anyway of getting rid of it???
Posts: 195 |
Mine is hot, too. Any advice (besides don't drive??)
Mushu's pretty cool too!
98 Black/Blue SVT #3829 of 6535
