Posts: 1,040 |
Originally posted by Eli: nope, you gotta set the knob on the left to a/c or max a/c A/C also on when mode switch is on floor/defr or defrost.
Posts: 1,040 |
Originally posted by themannn99: anyway of getting rid of it??? Well you could make sure heat shields under car are OK and also check that cabin air filter is OK.
Posts: 1,003 |
How would replacing the cabin air filter help? I've never replaced it and we've had lots of airborne stuff here in CO this year- pollen and ash.
Posts: 229 |
Originally posted by Bicycle019: How would replacing the cabin air filter help? I've never replaced it and we've had lots of airborne stuff here in CO this year- pollen and ash. The cabin air filter is replaced by first removing the black cowl panel located under the passanger side wiper. Pop off the trim caps and remove the two screws. Then open the hood and remove 3 more screws. You can now remove the cowl along with the rubber seal clipped onto it. Once this is done you can access the filter.
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 563 |
Originally posted by themannn99: ok when i open the windows and roof....driver side gets extreme heat from the pedal area. i have a stereo, so the power wire is through the firewall. but i honestly don't think that that much heat can get through. Is anyone else haveing this prob??? I have the same problem with mine. Its not coming from the engine I think it has to do with a flapper within the heating system. If it be vaccum or what not I don't know but it is definetely coming from the air plenum behind the cup holders. Settings are on cold with the blower off and other control is on off to. It could be the little vaccum canister hanging on the left side still letting air to to go through the heat side. I would like to find and explantion. The hair is about to melt off my legs.
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 1,053 |
Originally posted by Bicycle019: How would replacing the cabin air filter help? I've never replaced it and we've had lots of airborne stuff here in CO this year- pollen and ash. I'm sure it's trashed at this stage if if you have had all that junk in the air. It's a 20min jobby.
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 1,040 |
Originally posted by Bicycle019: How would replacing the cabin air filter help? I've never replaced it and we've had lots of airborne stuff here in CO this year- pollen and ash. Clogged filter will reduce outside airflow into car.
