Posts: 157 |
My cousin and I decided to install my DMD. Everything was going great until my cousin took of the original crankshaft pulley bolt and used the puller without it. This stripped the threading inside the crankshaft pulley.  I went to Autozone to rent their equipment in hopes that I could re-thread the crankshaft, but the tool isn't able to get in and start making a new thread. Probably because it has been worn down from over-use. Any other suggestions would be greatly appreciated. If I was Bruce Banner, I would have turned into the Incredible Hulk about 300 times by now.  Please help me before I loose it!!!!  Thanks
98 SVT E0 T-Red
E1 engine
resonator removed
K&N w/ MAF adapter
20% tint
Ford Trans. cocktail
Ford 9mm Racing Wires
DMD
Posts: 2,469 |
Are you sure you cross threaded the crank shaft? the crank is pretty strong. And even if you did you could prob. just retap it. Im sure alot of people are gonna respond to this But im sure this isnt A huge prob. like you might fear it to be.
Posts: 157 |
 I was able to borrow a better tap set from a buddy. Problem solved
98 SVT E0 T-Red
E1 engine
resonator removed
K&N w/ MAF adapter
20% tint
DMD
Posts: 2,061 |
lets us know how the rest of the install goes
99 expedition eddie bauer, 5.4 v8, k&n drop-in, 3" magnaflow catback and gas mileage that makes the contour look like a hybrid
Posts: 1,788 |
For future reference, could you post what size/thread pitch tap it was that you had to use.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 1,786 |
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 1,099 |
Why would you need to use the original bolt to pull the pully?
--Matt
2003 Sonic Blue SVT Cobra Coupe
2003 RedFire SVT Cobra Convertable
2005 Dark Toreador Red F150 XLT 4x4
2000 Black SVT Contour - Beater
Posts: 644 |
Originally posted by mmars: Why would you need to use the original bolt to pull the pully?
--Matt
It's what the puller pushes against for leverage. If you don't use the bolt, you'll end up stripping the threads on the crank... hmmmmm
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 157 |
Originally posted by projectSHO89: For future reference, could you post what size/thread pitch tap it was that you had to use.
Steve
Sorry, its hard to think when your angry.  M12 1.5 I believe.It just wouldn't catch because the starting tip was so flat and dull.
After I was able to tap a new thread, everything went pretty smoothe.
I'm just happy to have a little more peace of mind knowing my car won't be so prone to crank whip, now that I have a DMD on my car.
98 SVT E0 T-Red
E1 engine
resonator removed
K&N w/ MAF adapter
20% tint
DMD
Posts: 1,325 |
Originally posted by delmar: Originally posted by mmars: Why would you need to use the original bolt to pull the pully?
--Matt
My craftsman puller came with a few end caps to avoid pushing on the threads of the crank. Forget if I used the flat cap or the rounded one - but it got the stock pulley off with no thread issues.
97 Contour SE MTX
04 Grand Caravan SXT
