Posts: 10,015 |
Bring over your disconnected caliper and we'll slip her on and see. I think the rotor offset causes an issue with the outer pad interference.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
oh, I've got brackets and rotors, I just haven't had time to monkey with it. I'll see if I can take a few minutes tonight and look at it.
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by Stazi: No. As you cannot use those brackets on the Contour calipers. They are different! I checked.
You didn't check very close . . .
You can use the FSVT anchor bracket with the contour caliper. The only differences from the full FSVT brake swap, is you pull the stock anchor bracket out, and slide the FSVT one into the stock caliper (be sure to re-grease the slide pins w/ brake grease); you also must modify the pad backing plate. The outer FSVT pad backing plate won't seat into the caliper quite right becuase of the profile of the top of the pad; take a grinder or cutoff wheel and shape the bump on it to match the bump on the top of the CSVT pad. You could use CSVT pads I suppose, but they require a bit of grinding down on the sides to clear the FSVT anchor bracket. I didn't try this.
Other than the swapping of the anchor brackets, and the re-shaping of the outer pad backing plate, this is identical to the full FSVT swap. Too bad the FSVT anchor bracket was never released as its own service part.
On Edit - btw, I verified this all tonight on my E1 CSVT
Posts: 10,015 |
I don't like the idea of grinding anything on brakes.
AUSSIE ENDLINKS $70
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by Stazi: I don't like the idea of grinding anything on brakes.
It is a completely non-structural portion of the pad backing plate, only used for alignment to the caliper body.
Last time I checked, I knew a thing or two about brakes myself. I have no qualms about the clearancing I did to the backing plate.
Posts: 4,639 |
so the bracket cant be ordered on its own then?
Hugo AIM:omegazodiac
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
That is the unfortunate truth. I tried, but I came to the party too late on the FSVT to get it released that way.
Posts: 661 |
Originally posted by todras: All the brackets are the same! Only the calipers changed.
SVT (1998 to 5/1999) cars are equipped with larger 278 x 24mm front rotors and larger ATE calipers and pads than standard Contours.
SVT (after 5/1999) also equipped with larger 278mm front rotors but with Cougar calipers that utilize the slightly smaller standard Contour pads
I will disagree with that, I have an E0 svt, and it seemed that one of my brakets was tweaked. I have some E1 braket that I was going to replace it with and they wouldn't bolt up to the knucle.
Fast Cheap reliable
Pick two
Posts: 126 |
99 Contour LX MTX, Cone Air Filter, Custom Grille
95 Neon ATX Intake, Ractive Muffler, Green Painted valve cover, fuel rail, and intake, b/w painted interior, white exterior trim, shaded tail lights
Posts: 5,810 |
I got an extra wheel hub and some steel along with measuring everything to see what would happen with a bracket that will allow the CSVT brackets to fit FSVT rotors. It definitely will fit. Just have to be creative on the way the adapter bracket is mounted. I've completed my preliminary sketches and measurements today and I think I'm going to make myself a set to see how it will come out.
See My Mods
