Posts: 2 |
Okay, correction to my post above... since I have a 2000 CSVT, the old caliper won't work with the new bracket and pads as I was hoping. I did the complete change to FSVT parts last week and had no problems (calipers, rotors, and pads). A noticeable improvement to braking performance, to say the least.
If you're like me and have a 2000 or 99 (built post 5/27) CSVT, you can't do just the bracket and pads... gotta' get the new caliper.
To answer an earlier question, I was intending to get the FSVT bracket from Murray's or some other discount store. I'm pretty sure you can get a re-manufactured caliper and bracket for dirt cheap (less than $40?)... just use the bracket. That's a small price to pay rather than tring to fab up your own bracket. But this only works for those who have the older (pre-5/27/99) CSVT caliper.
Good luck!
Posts: 2,097 |
I would like to know where you actually found or if you did...the fsvt brackets only.
98 E0 SVT with some stuff
Posts: 4,639 |
so your saying my 4/99 built 99 can just use the fsvt bracket and rotors on my stock calipers? cuz that would be awesome. what type of spacers exactly? where would i find them?
Hugo AIM:omegazodiac
Posts: 201 |
Hey guys, here is the pricing breakdown on the FSVT conversion. This kit comes with New calipers pre-loaded with pads and brackets, and rotors And the 4 new bolts you need. you can pick up the 3mm spacers locally from what I am told.
2M5Z-2B120-AA List $173.35 CEG $130.01 Core $70 2M5Z-2B121-AA List $173.35 CEG $130.01 Core $70 2M5Z-1125-AA List $85.00 CEG $70.07 X 2 $140.14 W500443-S426 List $2.19 CEG $1.64 x 4 $6.56
You would get the $140 in cores back when I get the old calipers back, in the original boxes.
Bill Jenkins
I am moving to Team Ford as of 08/01/05 (www.teamfordlv.com). I will post new info when it's ready.
Posts: 4,639 |
bill, is there a part# for just the brackets and bolts?
Posts: 10,015 |
No. As you cannot use those brackets on the Contour calipers. They are different! I checked.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,399 |
I thought that in an earlier post it was established that the E0 calipers would fit the brackets......
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 10,015 |
That I cannot say as I have an E1.
AUSSIE ENDLINKS $70
Posts: 21,197 |
All the brackets are the same! Only the calipers changed.
SVT (1998 to 5/1999) cars are equipped with larger 278 x 24mm front rotors and larger ATE calipers and pads than standard Contours.
SVT (after 5/1999) also equipped with larger 278mm front rotors but with Cougar calipers that utilize the slightly smaller standard Contour pads
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Stazi, where is the issue w/ using the E1 calipers on the SVTF anchors? I've briefly looked at them but not side by side. (haven't had a chance to unfortunately) the slide pin spacing is the same, the mounting dimensions are close enough. . . is it something with the pad clearances?
