#626956 05/06/03 09:59 PM
1
1
All of the sudden whenever I get a 1/4 of tank or lower my car acts liek it's about to run out of gas. I once went up a steep hill and my car just died until it leveled out. My gauge is not off because I still put the same amount in as before. Any one have any ideas???
Silver Frost 2000 SVT #1443 of 2150 http://photos.yahoo.com/hpick1
#626957 05/06/03 11:18 PM
H
H
Your fuel pump is dying. If you're not comfortable with dropping the gas tank to change the pump yourself, you should take it in to a mechanic to have the job done.
#626958 05/07/03 02:31 AM
H
H
fuel pump how-to , perhaps of interest.
#626959 05/07/03 03:44 AM
Often the main problem is not the pump itself, but rather the flat filter screen on the bottom of the fuel pump module. Try taking the filter off and throwing it away. You don't need it. There is still a conventional sock filter on the inlet pipe to the pump inside the pump module. The flat filter screen is too fine and does not have enough surface area. Check the fuel inside the tank and make sure that it is not contaminated. You just might save yourself the cost of a new pump. If you do end up replacing the pump, throw the filter screen from the new one away. If you look at the pictures at the very bottom of the how to link you will see the filter screen that I am talking about.
