Page 2 of 3 1 2 3
Usually, you'd look at the Qts. value of the driver. If it is a high Qts rating.. somewhere around .5 and higher, the driver would be ideal for free air use. You can use a driver with a low Qts under .5, but the powerhandling due to mechanical limits would drop substantially. A driver with a high excursion, and a Qts of about .4 would also work effectively in a free air situation. You should just beware of not pushing your driver so hard, it would bottom out.
Ren
Remember this is why we're at war! I'm now officially a troll! 2004 Saturn ION QC with Sport Package AIM/AOL: animusshinigami
Hey Tony,
What about a pair of Apex Jr. 8" Super Sub's (total of $70) from www.apexjr.com? QTS = .514
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
I feel Guilty, Oh so guilty
At first, I thought the apex woofers would be ideal, but the xmax turned out to be around 4.5mm which isn't too good. He would be dropping his excursion capabilities by 70%.
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
Hmmmm... Forgot about the low Xmax on the Super Subs.
What about a pair of Dayton 8" Quatro Subs? Lots of good comments about 'em on the PE tech board over the past coupla months.
QTS = .40
Xmax = 9.5mm
RMS = 150w
Price = $49.72/each
Alright, they're not 8" speakers but will still easily fit as 6x9s.
6x9 Subwoofer - 2ohm
Xmax - 8mm
Qts - .80
RSM - 50w
Price - $4.89/each
You could probably fit up to 4 or 5 of them across the rear deck (at a total cost of only $25). They won't need a baffle either due to the included spacer. The 2ohm impedence gives you some interesting wiring options too.
Xmax - 8mm
Qts - .80
RSM - 50w
Price - $4.89/each
Isn't the Qts a little high for a free air sub?
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
"Qts - This is the total strength of the driver resonance. It is a combination of electrical Q (Qes) and mechanical Q (Qms). A speaker with high Qts will have a very stiff suspension."
As I understand it, speakers with stiffer suspensions are better suited to infinite baffle (free-air) applications as they are less prone to over-excursion.
The actual bass output is derived from the conal surface area and Xmax (excursion capabilities) of the driver. The more air the driver moves, the more bass you'll create.
This sub has a pretty high QTS of .8 which should help keep it from being overdriven. And, it's Xmax is also pretty darn long for so small a sub at 8mm (not a point-to-point measure which some manufacturers use to exaggerate specs).
BTW, I believe this driver was designed to be a free-air 6x9 sub.
I suspect 4 of them could move quite a bit of air with even a very modest amp (something that'll produce 100x2 @2ohm stereo - a dime a dozen amp). And, zero loss of trunk space!!!
Tony D Offline OP
Thanks for all the help guys.
I am gonna go with the Illusion Audio LM-10 (10").
This is thier free air sub. Thanks for all the help!
I post pics when it's in.
Ordered from SOLEN INC.
1998 Contour SE Panasonic CQ-DFX683 Sound by Crystal Mobile & Illusion Audio Powered by Alpine MRP-F240, Alpine MRP-M350 My Ride
Those are neat subs. I tried getting one a while back but never found a place to order them. Good luck on the install. You'll probably have to make a 1.5" baffle (couple pieces of 3/4" MDF sandwiched together) for a free-air install.
I think a pair of ND-804's would sound fantastic in the front doors.... Can they handle mid-range up to 2500Hz or so? Might have to give Solen a call....
Illusion Audio subs and speakers are in stock and available at www.solen.ca FYI.
Previous owner of a 99 Mystique V6 MTX Black Current owner of a 2004 Maxima SE MTX Silver Forsale: Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Page 2 of 3 1 2 3
Moderated by  dnewma04_dup1
