Posts: 319 |
Once again my system has changed in this car. Goodies went to another car. I now need an 8" for some bass out of the deck hole.
I need something better than this
Illusion Audio LM-804 Price is $109 cdn.
Thanks.
1998 Contour SE
Panasonic CQ-DFX683
Sound by Crystal Mobile & Illusion Audio
Powered by Alpine MRP-F240, Alpine MRP-M350
My Ride
I feel Guilty, Oh so guilty
Posts: 4,789 |
That's a tough woofer to beat for the application.
Elemental e8A is a possibility as is the Kicker L7 8.
-Mitch Hedberg
Posts: 319 |
Dave,
you think that woffer will pull it off? I realy like it but am unsure about the sound.
1998 Contour SE
Panasonic CQ-DFX683
My Ride
Posts: 4,789 |
Have you thought about using two of them?
-Mitch Hedberg
Posts: 319 |
i figure if i was gonna use 2 8's in the rear deck maybe i should just use 1 10". What do you think?
Unless i put them in the rear door.
1998 Contour SE
Panasonic CQ-DFX683
My Ride
Posts: 4,789 |
Using a 10 in the rear deck could work very well and wouldn't be a ton of work.
-Mitch Hedberg
Posts: 319 |
would the Illusion Audio LM-10 be a good choice for this?
1998 Contour SE
Panasonic CQ-DFX683
My Ride
Posts: 4,789 |
The low Q makes will make the bass very tight, but somewhat lacking in qty. The xmax is good and with some EQ, you could increase the low end output.
-Mitch Hedberg
Posts: 319 |
Thanks, I'll order tomorrow.
1998 Contour SE
Panasonic CQ-DFX683
My Ride
Posts: 3 |
I am working on getting to understand this stuff. I haven't sorted out the various "Q"s out there... If I'm looking for free air use (trunk) for what values, roughly, am I looking for? I only know there are usually three Qs, "Qms", "Qes" and "Qts".
Chris
1999 SVT T.Red
