Posts: 14 |
 I am new to the board and have been trying to find some cheap ways to make my 1995 2.5L a little bit faster and was looking for some input. I was thinking an air filter and the SVT exhaust, was wondering what people thought of these mods and would I see noticable gains, also the best brand of air filter for this application. I am open to other options for performance gains, I want to get an exhast system but do not want that raspy Honda sound. Thanks.
Jared
You might be a bracket racer if, you would rather be lucky than good.
95 Contour SE
65 Mustang
Posts: 7,025 |
i recommend the 7" K&N. ive seen quite a few people running that and is better than the KKM intake since the KKM causes turbulent airflow. Also, if your looking for the best sounding exhaust, I personally think true duals is the way to go. It can be a bit pricey ($300-1200), but it probably nets the best hp gains properly setup, best sounding with little to no rasp, and gives a deep sound. Other mods you may want to consider that are cheap would be an optimized throttle body and maybe even optimize your secondaries, gut the precats (do not gut the main cat!), clean your UIM/LIM for any carbon build up and possibly port match, and possibly an Apexi S-AFC which you can pick up for like $300. The Apexi may or may not give much more peak hp, but from observing from the dyno day this weekend, after tuning the Apexi, it gave quite a bit more power under the curve through out the entire rpm band. Just my .02
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,355 |
you know other cars can sound "raspy" not just hondas and imports alike.....you dont do your exhaust mods right and that duratec of yours can sound pretty raspy as well....
--Chris--
1999 Silver Frost SVT
#1671 of #2760
Posts: 257 |
Jim, does it matter if the K&N filter is tapered or straight? And what is the biggest filter that will fit in the SVT's?What entails in optimizing the throttle body? I think I've already asked you about this.  OK no more questions
99' Contour SVT Amazon Green
#299 of 2,670
"Maggie"
Many mods on the future "to-do" list
marines puttin me on hold.....go figure
Posts: 7,025 |
i dont think it matters if its tapered or not, but from my understanding about the kkm, the inverted cone on the end causes turbulent air. the biggest filter ive known that will fit is a 9" K&N. The optimized TB includes replacing the stock throttle body plate screws with some flush mount screws or pop rivets. im not sure which one rick blackford uses. Also sanding down the TB plate to tapered edge for better airflow and sanding down the inside of the TB. Optimizing the secondaries pretty much includes the same thing.
Jim Hahn
Posts: 14 |
What do ya'll think about this purchase...
K&N Air Filter
OR
2nd Option
Jared
95 Contour SE
65 Mustang
Posts: 68 |
I would look else where. Do a search for K&N on yahoo and see what you get.
Canada = little France
Posts: 1,254 |
i was very close to doing the throttle body op. but when i pulled the vacume hose off there was a sticker there saying something like not to adjust the screws because of some kind of film or coating. i called Ford and they said that the screws are "welded" in and cant be removed and risk breaking the cross bar or bottom of the plate.
Posts: 1,272 |
I don't think it matters whether it's straight or not, jut make sure it fits!! 12$$ for shipping?!?!? Screw that!!! Someone from the boards purchased a K&N from Summit.....anyone know the filter # that works for our application???
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA
NECEG "Troll"
formerly owned 2000 SVT Contour, with all kinds of goodies;)
Posts: 2,857 |
Originally posted by wontgrowup: I don't think it matters whether it's straight or not, jut make sure it fits!! 12$$ for shipping?!?!? Screw that!!! Someone from the boards purchased a K&N from Summit.....anyone know the filter # that works for our application???
a k&n ru-3530 works perfectly.....that's what i have,and i love it...you will need a maf adapter(can be obtained from several sources)and make a heatshield...made mine out of a $3 rubbermaid dish tub....
you can get a k&n ru-3530 from www.ajusa.com for $33.11 shipped......just click on k&n store,then k&n part #.....i got mine from them...great service....
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
