#62453 06/04/02 07:55 AM
My '94 1.8 Mondeo (132K miles) has just failed the UK MOT Emissions Test due to too high a level of Carbon Monoxide at both "natural" idle and fast idle. I had a new CAT, plugs, leads, coil fitted two months ago.
Took it back and the first suggestion was some o-ring - replaced for $50 - no difference. The next thing they say they want to replace is the exhaust manifold gasket. Any suggestions how to avoid a long and expensive series of guesses.
Malcolm
#62454 06/04/02 04:41 PM
H
H
Check the computer codes first. If you don;t know how to do this, it is easy, and descirbed in the Haynes manual. You just need a meter, no special equipment for your year.
1995 V6 GL 5 spd
No mods
92,000 miles, just broken in
#62455 06/04/02 08:42 PM
Q
qaz Offline
Q
Maybe the O2 sensor needs to be replaced? Is it original? If so, it's definently toast.
Brian
#62456 06/04/02 10:11 PM
Well,
Check these pages
http://www.apcd.org/vet/failedveh.htm
http://www.txdps.state.tx.us/vi/publications/brochures/Failure_copy.htm
It gives a pretty good indication. Check the simple stuff like your air filter and your O2 (lambda sensor).
Originally, I was thinking a high CO was a lean mixture, but this
says it's probably too rich.
TB
Tony Boner
