Posts: 477 |
I've been noticing that the steering in my 96 SE seems to be getting more loose now that the car is getting up in car years (90k miles). Would replacing the power steering pump correct this? Does anyone know how to fix a loose steering condition?
1996 Contour SE Red V6 MTX 1995 Contour LX Champaign V6 ATX (my wife's beater) SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Posts: 1,040 |
Power steering pump, no; tie rod ends, yes.
Posts: 515 |
Don't forget Ball Joints and control arm bushings can cause this too.
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 477 |
Originally posted by horseydug: Power steering pump, no; tie rod ends, yes. cool. any idea how compicated a job it is to replace the Tie Rod ends? or do I just need to tighten them up? is it pricey to have a shop fix this for me?
Posts: 5,805 |
Rod ends first,outer...the inners are part of the rack.....
Posts: 1,040 |
These are wear items, replacement only (about $25 each plus labor), followed by alignment. From your posts, however, I would recommend you get a front end inspection and see what sort of problems a shop could identify.
