Page 4 of 7 1 2 3 4 5 6 7
72,000
David AIM: DaveL225 2002 CD Silver Focus SVT 2565/4788
Originally posted by DanB:
The owners manual says to do the drain/refill/drain/refill procedure every 30K. Should get out up 6 quarts of fluid.
Also add a bottle of Lubeguard. Heard its pretty good stuff.
You can't listen to the owners manual.
I did and I am on my third tranny.
You've got to change the oil every 12,000 - 15,000 miles.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
2
Almost 70k on mine. I change the fluid often because it is so hot here and I drive in a lot of traffic from time to time. Been using Mercon V fluid, shifts a bit smoother since then. Don't know how much longer Tour #2 would have gone. My wife traded it for a Mazda Tribute when it had 50k on it.
With my zetec that vibrates so much at stoplights I shift it in to neutral at just about every stop. Is this hard on the tranny or is it good?
Mystique LS
CEG road warrior
CEG road warrior
Using Mercon V!!!!!????? Read your owners manual it says specifically not to use it.....it may cause DAMAGE!!
CEG road warrior
CEG road warrior
It isn't bad. Most Zetecs have a fairly rough idle and no probs with the trans.
Mine choked at 91k. These CD4E are really [censored] transmissons.
and lancers are really [censored] cars.
CEG road warrior
CEG road warrior
Not this guy again!
My car does it as well and always has sence I got it back when it had 34k on the dail.
97 Mystquie GS - I4 ATX died at 168K 94 Pontiac Crap AM SE - 2.3L I4 5spd 2002 Mazda Protege5 - 2.0L ATX
