Page 4 of 9 1 2 3 4 5 6 7 8 9
Originally posted by ZetecNinja:
check batinc.net & spmotorsports.com & ctamotorsports.com for parts
there is a how to on the main page for installing springs & struts...if you don't know how take em to a shop for around $200-$300 unless u get a good deal
Are you serious !? How much cheaper would it be to install just springs ?
98 svt
About the same.
You have to remove the struts to remove the springs. So you might as well do both at once, or you're going to have to pay $300 to install the springs and another $300 to install the struts a couple months later when they blow out.
Suspension work is not easy.
It will take a mechanic a good 4 hours to do, and the average person almost an entire day to do it.
EDIT: It would probably be more correct to say it will take a couple mechanics to do it. Suspension work is not a 1 person job unless you're particularly masochistic.
2003 Mazda6s 3.0L MTX Webpage 2004 Mazda3s 2.3L ATX
thats exactly what i was going to say and exactly why i decided to pay a mechanic to do both instead of doing it myself and messing somethin up nicely. wallets a little hurt everything will work when put back together.
1999 SVT #336 Tropic Green 19" Axis Se7ens INJEN intake OMP Strut Brace HPP Rear Brace B&G Drop www.cardomain.com/id/svtpyr8
mechanic should be able to do it 3 hours if they've done a contour before. after you do it the first time, it's actually pretty easy. It took us about 1 hour each side of rear. It then took 2 hours on one side of front to figure it out, but then only 45 minutes on other side.
I had no clue it was so hard and expensive. Guess I wont be dropping my car anytime soon. Damn, this is really bad news for me
98 svt
I
I
I know I'm not hearing this from a guy with an SVT
whats the price tag on those again?
I
I
I'm in $85 how can you go wrong. Has anyone have an idea if the spax TA adjustables are avialable yet? I seen a post on the SP motorsports page but its an old post. I just hope they're cheeper than the KONI struts.
98 SE V6 MTX T RED bridgestone potenza re950 open air filter side makers and removed ding guards , gutted percats, no muffler SVT brakes SpecIII cluch and spec flywheel torsen diff soon
85 for all 4!
Jason 00 Audi S4, 2.7 Bi-turbo quattro 01 S10 Xtreme, 4.3l 98' Contour SE with some mods 96 Cavalier (beater)
My SVT was only 10k, thats not too terribly expensive. Also, it may not be because I cant afford $300 to install springs, its that I feel thats too big of a waste. Especially considering I most likely wouldnt be able to get up/down my driveway anymore.
98 svt
I
I
I agree too...but this will probably be the best deal you'll ever get on springs...so in the long run you aren't spending that much
plus if you get someone that knows what they're doing your install is free.
Moderated by  1314_dup1
