Posts: 4,970 |
$9 isn't bad!! It's about 40 LBS lighter than a "normal" aluminum cased MTX75.......and for $9.....wow
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 152 |
wow thats cool I wish I lived near him. $9 is a great deal.
98 SE V6 MTX
T RED
bridgestone potenza re950
open air filter
side makers and removed ding guards , gutted percats, no muffler
SVT brakes
SpecIII cluch and spec flywheel
torsen diff soon
Posts: 1,603 |
If this is an MTX-75, the bell housing is not right for the Duratec. If you look at the Bell housing picture, the starter would go on the engine side of the bell housing.
Unless I am wrong, IIRC, the starter goes on the transmission side of the Bell housing, between the battery and the Brake Master cylinder. Unless that is just the way it works for automatic transmissions. But it looks like the way it is set up, the started would never clear the side of the Duratec engine block.
This *might* be for a Zetec engine....
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 3,506 |
Magnesium is a great ligth weight metal....but extremly volital at high heat. I wouldn't want this on my car. In my opinion of course.
I Read about some guy in road and track that built an all Magnesium race car and DID NOT put seat belts...he would rather be thrown from the car, then die in a raging fire because of how fast Magnesium burns...givin this is only a transmission, but just how close is it to you tank and fuel lines....I know thinking about it is bad...but its a reality when people use this metal.
Roz
Posts: 4,970 |
Originally posted by Roz 1999 SVT-C: DID NOT put seat belts...he would rather be thrown from the car, then die in a raging fire because of how fast Magnesium burns...
LMFAO
Damn, there goes that idea!
I have heard from a reliable source that if this wasn't from across the pond then it isn't worth looking into.
Posts: 5,854 |
um...are th eoperating temps of this car high enough to make the trans burst into flames??
1999 Silver Frost SVT
#609 of 2760
Posts: 3,506 |
No...sorry i should have been more descriptive...i meant in a accident....If anyhting were to catch fire in the engine bay, and the magnisum of the trans were to catch, it would burn uncontrolably and since the trans is the closest part to the fire wall, that is bad....but it is a great way to save weight
Posts: 3,718 |
...there's a reason Magnesium is used in flares...
JaTo
e-Tough Guy
Missouri City, TX
99 Contour SVT
#143/2760
00 Corvette Coupe
Posts: 4,970 |
Where do you think the term "Mags" for wheels came from?? It was those old cabbage shredders and other style wheels made out of magnesium in the 60's. (I wasn't even born 'till '79  )
