Page 2 of 2 1 2
"Absolut Rara."
"Absolut Rara."
some detailed pics might help here.
Balance is the Key. rarasvt@comcast.net
Cool Toe Chris
Cool Toe Chris
Agreed, I'm kind of lost here.
Chris NJ 98.5 SVT Silver Frost
C-Tec Offline OP
sorry about the bad spacer picture... but it give you an idea
first one is passenger side, second one is the ghetto spacer (2mm), third drivers side
Turbo'd Cougar 2.0L w/ 75 shot ... its got some stuff in it ... NOT that fast NOT that furious :P
Ah guys, the spacers you are looking for are 12mm flat washers. sheees. Measure the bolt.
The fact that these are floaters makes the install pretty simlpe as you can pull the caliper more off center as needed as long as the bridge of the caliper clears both sides of the rotor.
When you get your washers take a mic with you to the hardware store and measure them. This way you'll get ones that are the same thickness. (or you can get ground shims from me in various sizes) This will help keep the caliper square to the rotor.
I can also supply you a thin .090" wheel spacer that will cure your problem to the spokes easily.
The piston in the Focus part may be a bit larger, no notes here at home, so the pedal travel will be slightly more if that's the case. But it should firm up down a bit deeper if it's bled properly.
Less Bling, more Zing Todd/TCE www.tceperformanceproducts.com
nevermind....i didn't read all the posts.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
C-Tec Offline OP
from what it kinda sounds like, i think thats the CALIPER touching the rotor. and thats where the sound while turning comes from... kinda wondering why its while im turning... maybe its cuz of the way the wheels turn... im gonna go snag some 3mm spacers and then update you guys after bleeding it again.
C-Tec Offline OP
OOOKkk, i replaced the old spacers with new thicker ones...wonderful, no noises and all is well that ends well. Thanks for the help guys!!
Page 2 of 2 1 2
Moderated by  Andy W._dup1
