Page 3 of 4 1 2 3 4
#617371 05/07/03 10:47 AM
I had NO problem when I was running the 9005 Silverstars in my ride, noone flashed me or anything The Silverstars are $20.00 a piece at our local Autozone and come as single bulbs, not a twin pack I can't believe this post has so many people questioning how good these lights look because for $50.00 its quite an upgrade and as far as using the 9006's instead of the 9005 Silverstars, why in the world would you do that
#617372 05/07/03 12:35 PM
Originally posted by wontgrowup:
Just for laughs I took a set of Hiper 9005 bulbs I bought off of Ebay awhile ago and tried the "swap". My impression?? Imagine shining a flashlight into a bunch of mirror shards....that's the best description I can think of. Maybe somethings up with my reflectors on the stock headlight housings, but that's what the beam pattern (if you would like to call it that) looked like. Yes, there is more light, but it is very unfocused and VERY scattered!! I put my 5100k 9006 bulbs back in, and decided that I am quite happy with those (and the 885 fog upgrade).
My beam isn't scattered at all.
Maybe you didn't have the bulb seated properly. That will cause the beam to be way off.
1998 T-Red SVT #957 Born 5/14/1997
#617373 05/07/03 10:35 PM
W
W
Hmmmm.....maybe I should check the bulb "seating"....Also, I'm not "picking" on the Silverstars, i was making a blanket comment on the 9005's in general. Silverstars are a great product and have a great reputation, so chill.....
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA NECEG "Troll" formerly owned 2000 SVT Contour, with all kinds of goodies;)
#617374 05/07/03 10:42 PM
Was there any statement in my post where I wasn't chilling?
#617375 05/08/03 02:50 AM
W
W
"Chillin' like gilligan stranded on an island" geez, am I making myself sound old or what....
My apologies....the freakin' bulb had actually popped out of the headlight assembly, which (as one person figured) caused that wacky "scatter" pattern. The light is definitely brighter!!!
#617376 05/13/03 07:16 AM
Originally posted by The Striped SVT:
NO BRAINER here, 9005 (high beams) Silverstars installed into the low beam socket. Just file down the little tabs so they're flat and thats it. The difference is amazing and you WILL NOT blind any oncoming drives, unless your headlights aren't aligned properly, so don't let someone tell you otherwise This is the best $40.00 you can spend because these lights put out a bright, white light and don't let the light blue/purple color of bulb fool you, they're really, really white
I did the SilverStar 9005's in the low socket swap today. Besides filing the tabs inside the plug, I also had to take a chip out of the skinny leg of the part that mates to the housing. It was just different enough that I couldn't get the bulb to pop in. Once in, all good. The light output is amazing. I was hoping for a more white color. I wouldn't even call 'em white really. They look pretty yellow to me. They match the stock brights / fogs perfectly color wise. The light output is a whole 'nother deal. The beam pattern on the ground is much more HID like. Definately worth the money.
I prefer the blue / purple hue of the Audi HIDs (7500-8000k I believe). I may bite the bullet and convert the low beams to HID one of these days. Right now I'm deciding whether to ditch my 'Eurolite' 9007's in the Mustang in favor of a set of the SilverStars.
Shawn
'98 Contour SE Sport v6 ATX - totaled in August of '05 '95 Mustang GT Convertible - 5-Speed.
#617377 05/14/03 11:50 PM
Mine should be waiting for me in the mailbox when I get back from vacation. I can't wait to switch 'em out!
-CHRIS
#617378 05/28/03 08:01 PM
I just got mine slapped in and I love them. Much better!
-CHRIS
#617379 06/05/03 03:45 PM
Alright well i just got some, (9005) and I see the two notches i have to remove. I tried using a razor, but it wouldn't work. Any suggestions? Thanks
TPC Northville, MI 2002 - Pitch Black Focus SVT (Red Trim) Steeda Short Ram Intake 5% Tint All Around 98 Contour SE Zetec ATX - *RIP* @ Charity Motors
#617380 06/05/03 04:00 PM
Sharper razor.
Seriously, I used an Exacto knife with a fresh blade and whittled the tab away in 5 seconds flat for each bulb. IT might take a few seconds more with the razor blade cause its bigger.
Page 3 of 4 1 2 3 4
