For the Lincoln, it depends. Here's why:
If you look at our headlight set up, our low beams have deflectors in them to keep the beam on the ground. When you stick the high beam bulb in, it'll stay on the ground but just be brighter.
The Lincoln will need to have deflectors in the headlights for the high beam bulb to work or you will end up blinding oncoming traffic. If there's deflectors in ther, go for it.
