The base of the perches are welded to the strut. You're best bet will be to make about 1/4 to 3/8 of an inch above the weld, Mark with permanent marker, and use a hacksaw to remove the perch. The more level your cut the better the coilover stopping plates will sit. Be very very careful not to go to deep. You don't want to damage the stru house. We had to use a hammer to break the perch loose and slide it over the top. Once you see the struts, it should make more sense.
-Andy
