jbl 2003 now offers some 6x8 models with ford drillings
jbl 2003 6x8
GTO8626 6"x8" (5"x7") 2-Way
pecifications MSRP US$: $119.95 Pair
Power Handling, RMS: 60 Watts
Power Handling, Peak: 180 Watts
Frequency Response (±3dB): 50Hz - 21kHz
Sensitivity: 90dB
Mounting Depth: 2-7/16"
Cut-Out Diameter: 7-3/16" x 4-15/16"
P8652
MSRP US$: $229.95 pair
Power Handling, RMS: 75 Watts
Power Handling, Peak: 210 Watts
Sensitivity: 90dB
Frequency Response (±3dB): 40Hz - 23kHz
Impedance: 4 Ohms
Computer-optimized voice-matched passive crossover-The P8652 comes equipped with an outboard crossover that has been voice-matched to ensure optimium imaging, clairty and detail.
GTO8606C
MSRP US$: $229.95 Complete System
Power Handling, RMS: 70 Watts
Frequency Response (±3dB): 55Hz - 21kHz
Sensitivity: 90dB
Mounting Depth: 2-7/16" Mid-Woofer, 1-3/16" Tweeter
Cut-Out Diameter: 7-3/16" x 4-15/16" Mid-Woofer, 1-3/4" Tweeter
Impedance: 4 Ohms
Plus One (patent pending) woofer cones - The GTO8606C's mid-woofer has a cone with more surface area than competing models of the same size. The benefits of Plus One are greater efficiency and bass output.
• Computer-optimized voice matched passive crossover - The GTO8606C feature an outboard crossovers that has been voice-matched to ensure optimum transistion from the mid-woofer to the tweeter.
• Edge-driven Kaladex tweeters - These are not commonly used w-domes, but full edge-driven domes like those found in higher quality home audio speakers. The benefits are increased power handling, reduced distortion, and increased efficiency. This technology also allows for better integration with the mid/woofer.
• I-Mount (patent no. 5,859,917) tweeter mounting system - This well thought out system allows easy and versatile installation of the tweeter in the GTO8606C component systems.
• Hi-roll rubber surrounds are used to provide excellent cone-edge suspension and damping. In addition this material will not brak down due to UV contamination or
